You're viewing a previously published version of this guide.  View latest version
Older Newer
JVC XL-333 Power Button Replacement
Romenick Casabar
Romenick Casabar and 5 other contributors
Last updated on May 7, 2024
30 - 35 minutes
Moderate
Introduction
Go to step 1
This guide explains how to replace the power button for a JVC XL-333 compact disc player. The steps are fairly simple, and you only need a few basic tools. Most of the steps only require either removing screws or using a spudger (or similar tool) to remove wires that are in the way.
  1. JVC XL-333 Power Button Replacement, The Power Button: step 1, image 1 of 2 JVC XL-333 Power Button Replacement, The Power Button: step 1, image 2 of 2
    • Using your Phillips Head Screwdriver, remove the four screws with the red markup.
    • Then, remove the three orange screws using your screwdriver.
  2. JVC XL-333 Power Button Replacement: step 2, image 1 of 2 JVC XL-333 Power Button Replacement: step 2, image 2 of 2
    • Remove the two Phillips screws on both sides of the CD Player.
  3. JVC XL-333 Power Button Replacement: step 3, image 1 of 3 JVC XL-333 Power Button Replacement: step 3, image 2 of 3 JVC XL-333 Power Button Replacement: step 3, image 3 of 3
    • Remove the top of the CD Player by holding each side of the roof then sliding it away from the front of the CD player.
  4. JVC XL-333 Power Button Replacement: step 4, image 1 of 3 JVC XL-333 Power Button Replacement: step 4, image 2 of 3 JVC XL-333 Power Button Replacement: step 4, image 3 of 3
    • The disk reader is located above the power button.
    • Push out these tabs on both sides of the disk reader.
  5. JVC XL-333 Power Button Replacement: step 5, image 1 of 3 JVC XL-333 Power Button Replacement: step 5, image 2 of 3 JVC XL-333 Power Button Replacement: step 5, image 3 of 3
    • Unscrew the four Phillips copper screws located at the four corners of the disc reader.
    • After the screws are removed, gently pull the disc reader up and out of the CD player.
  6. JVC XL-333 Power Button Replacement: step 6, image 1 of 3 JVC XL-333 Power Button Replacement: step 6, image 2 of 3 JVC XL-333 Power Button Replacement: step 6, image 3 of 3
    Tool used on this step:
    • Gently pull up to remove the two bunches of wires with a green connector from the motherboard.
    • Remove the two groups of wires with a white connector by using your spudger or tweezers to pull up on the side of the connector, opposite of the wires. It may require some force
  7. JVC XL-333 Power Button Replacement: step 7, image 1 of 3 JVC XL-333 Power Button Replacement: step 7, image 2 of 3 JVC XL-333 Power Button Replacement: step 7, image 3 of 3
    • These pictures offer other tricks and guidance on how to remove the wire connectors.
    • move your spudger or tweezer in an upward motion to release the wires.
  8. JVC XL-333 Power Button Replacement: step 8, image 1 of 3 JVC XL-333 Power Button Replacement: step 8, image 2 of 3 JVC XL-333 Power Button Replacement: step 8, image 3 of 3
    • Remove the rest of the wires connecting the motherboard to the CD player with your spudger or tweezers.
    • Remove the screw that connects the wire to the motherboard.
  9. JVC XL-333 Power Button Replacement: step 9, image 1 of 3 JVC XL-333 Power Button Replacement: step 9, image 2 of 3 JVC XL-333 Power Button Replacement: step 9, image 3 of 3
    • Find the power button trigger on the left side of the CD Player. It should be gray.
    • Push it a couple times to make sure it works. If not hold it 3/4 of the way and pull with some force.
    • Replace with a new one.
    • Replace the motherboard, reattach the cables and repeat the rest of the previous tasks in reverse.
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 14
All Time: 990
