Jabra CRUISER2 Status Display Replacement
  1. Jabra CRUISER2 Status Display Replacement, Front Plate: step 1, image 1 of 1
    • Use the iOpener tool to unglue the adhesive of the device. The link to the iOpener instructions are listed below.
    • iOpener Instructions
  2. Jabra CRUISER2 Status Display Replacement: step 2, image 1 of 1
    • Place the flat head of the bigger plastic opening tool in between the front plate and back plate.
    • Pull the tool toward the back of the device to pry it open.
    • Repeat this process over all edges of the device.
  3. Jabra CRUISER2 Status Display Replacement: step 3, image 1 of 1
    • Open up the device by pulling the front plate straight up from the back plate.
  4. Jabra CRUISER2 Status Display Replacement, Motherboard: step 4, image 1 of 2 Jabra CRUISER2 Status Display Replacement, Motherboard: step 4, image 2 of 2
    • Carefully detach the wire running from the speaker to the motherboard by unplugging it from the white socket.
  5. Jabra CRUISER2 Status Display Replacement: step 5, image 1 of 1
    • Using the PH000, unscrew the three 4.55 mm screws in the motherboard.
    • The names of the screwdriver heads are listed on the sides of each head.
  6. Jabra CRUISER2 Status Display Replacement: step 6, image 1 of 1
    • Remove the motherboard from the device by lifting it up from the back plate.
  7. Jabra CRUISER2 Status Display Replacement, Status Display: step 7, image 1 of 1
    • Using the PH000, unscrew the three 4.6mm screws in the status display.
  8. Jabra CRUISER2 Status Display Replacement: step 8, image 1 of 2 Jabra CRUISER2 Status Display Replacement: step 8, image 2 of 2
    • Disconnect the wires connecting the status display to the back plate. Do this by pulling the wire from the black socket.
    • Do this with the wires on both sides of the status board.
  9. Jabra CRUISER2 Status Display Replacement: step 9, image 1 of 1
    • Remove the status display by lifting it off of the back plate.
Spartacus
636 Reputation
5 Guides authored
Baylor, Team 8-13, Williams Fall 2014 Member of Baylor, Team 8-13, Williams Fall 2014
BU-WILLIAMS-F14S8G13
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 504
