Jabra Freeway Antenna Replacement
Alec Wilson
Alec Wilson and 3 other contributors
Last updated on May 7, 2024
15 minutes - 1 hour
Very difficult
Introduction
Go to step 1
The bluetooth antenna in the Jabra Freeway is what allows the device to connect with your cellular device. This guide will help you to replace the antenna in the event of a failure.
Tools
Show more…
  1. Jabra Freeway Antenna Replacement, Front Panel: step 1, image 1 of 3 Jabra Freeway Antenna Replacement, Front Panel: step 1, image 2 of 3 Jabra Freeway Antenna Replacement, Front Panel: step 1, image 3 of 3
    • Turn off the device before proceeding. Failure to do so may result in device damage or injury to oneself.
    • Remove the rubber pads from the bottom of the device using the spudger.
  2. Jabra Freeway Antenna Replacement: step 2, image 1 of 3 Jabra Freeway Antenna Replacement: step 2, image 2 of 3 Jabra Freeway Antenna Replacement: step 2, image 3 of 3
    • Remove the eight 6mm T9 screws.
    • Two of these screws are underneath the foam padding. This padding is glued on and will be destroyed in this process. Poking through the foam minimizes the damage to the device.
  3. Jabra Freeway Antenna Replacement: step 3, image 1 of 3 Jabra Freeway Antenna Replacement: step 3, image 2 of 3 Jabra Freeway Antenna Replacement: step 3, image 3 of 3
    • Gently lift the front panel off of the device and carefully rest it to the side.
  4. Jabra Freeway Antenna Replacement, Antenna: step 4, image 1 of 2 Jabra Freeway Antenna Replacement, Antenna: step 4, image 2 of 2
    Tool used on this step:
    • Carefully remove the rubber gasket using the tweezers.
  5. Jabra Freeway Antenna Replacement: step 5, image 1 of 2 Jabra Freeway Antenna Replacement: step 5, image 2 of 2
    • Remove the five 6mm T6 screws connecting the circuit board to the rear panel.
  6. Jabra Freeway Antenna Replacement: step 6, image 1 of 3 Jabra Freeway Antenna Replacement: step 6, image 2 of 3 Jabra Freeway Antenna Replacement: step 6, image 3 of 3
    • Remove the microphone from microphone slot using tweezers.
  7. Jabra Freeway Antenna Replacement: step 7, image 1 of 3 Jabra Freeway Antenna Replacement: step 7, image 2 of 3 Jabra Freeway Antenna Replacement: step 7, image 3 of 3
    • Excessive force may cause the circuit board to break, destroying the device.
    • Carefully use the plastic opening tool to lift the circuit board up.
    • The orange portion of the circuit board is glued into place, and a small amount of force is necessary to break it free from the adhesive.
  8. Jabra Freeway Antenna Replacement: step 8, image 1 of 2 Jabra Freeway Antenna Replacement: step 8, image 2 of 2
    • Use the tweezers to remove the antenna from the retaining clips.
  9. Jabra Freeway Antenna Replacement: step 9, image 1 of 1
    • Desolder the antenna wire from the circuit board.
    • Please refer to the soldering technique guide for instructions on desoldering and soldering.
Alec Wilson
741 Reputation
5 Guides authored
UMass Dartmouth, Team 4-8, Catania Fall 2016 Member of UMass Dartmouth, Team 4-8, Catania Fall 2016
UMASSD-CATANIA-F16S4G8
2 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 848
