Jabra Speak 510 Motherboard Replacement
  1. Jabra Speak 510 Motherboard Replacement, Outer Casing: step 1, image 1 of 2 Jabra Speak 510 Motherboard Replacement, Outer Casing: step 1, image 2 of 2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Motherboard Replacement: step 2, image 1 of 1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Motherboard Replacement: step 3, image 1 of 2 Jabra Speak 510 Motherboard Replacement: step 3, image 2 of 2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Motherboard Replacement: step 4, image 1 of 3 Jabra Speak 510 Motherboard Replacement: step 4, image 2 of 3 Jabra Speak 510 Motherboard Replacement: step 4, image 3 of 3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Motherboard Replacement, Motherboard: step 5, image 1 of 2 Jabra Speak 510 Motherboard Replacement, Motherboard: step 5, image 2 of 2
    • Using the T6 Torx Screwdriver, remove the four (4mm) screws.
  6. Jabra Speak 510 Motherboard Replacement: step 6, image 1 of 1
    • After removing the screws, take out the center covering to free the motherboard by lifting the tabs and pulling it off.
  7. Jabra Speak 510 Motherboard Replacement: step 7, image 1 of 2 Jabra Speak 510 Motherboard Replacement: step 7, image 2 of 2
    • Peel off the white adhesive to desolder the connections underneath.
    • Desolder the wires connected to the motherboard.
    • You can find soldering tips in the How To Solder and Desolder Connections guide.
    • Keep track of where the wires are connected. When re-assembling you will have to connect the wires in the correct spot.
4 other people completed this guide.
Jordan Murphy
717 Reputation
3 Guides authored
IUPUI, Team 2-3, Harley Spring 2016 Member of IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Members
8 Guides authored
3 Comments
Great walk-through... thanks
Walaa Maher - Reply
Be very careful when desoldering the connector cables! The soldering lugs are poor quality and tend to tear off the PCB
Thomas Sprenger - Reply
Hello
Where I can buy the motherboard replacement?
Regards
Lobo Gris - Reply
Past 24 Hours: 1
Past 7 Days: 17
Past 30 Days: 76
All Time: 7,625
