Jabra Speak 510 Speaker Replacement
  1. Jabra Speak 510 Speaker Replacement, Outer Casing: step 1, image 1 of 2 Jabra Speak 510 Speaker Replacement, Outer Casing: step 1, image 2 of 2
    • Using a metal spudger, peel back the foam pad on the bottom of the device to reveal six screws.
  2. Jabra Speak 510 Speaker Replacement: step 2, image 1 of 1
    • Remove the six 20 mm T6 screws from the bottom of the device.
  3. Jabra Speak 510 Speaker Replacement: step 3, image 1 of 2 Jabra Speak 510 Speaker Replacement: step 3, image 2 of 2
    • Remove the back plate and the grey foam underneath.
  4. Jabra Speak 510 Speaker Replacement: step 4, image 1 of 3 Jabra Speak 510 Speaker Replacement: step 4, image 2 of 3 Jabra Speak 510 Speaker Replacement: step 4, image 3 of 3
    • Use a small, pointed metal spudger to release the plastic tabs connecting the faceplate to the bottom of the speaker.
    • A small cable connects the faceplate to the device. Carefully disconnect the cable before fully opening the device.
    • Slowly flip the device open like a clam shell.
    • There are several wires soldered to the motherboard that prevent the faceplate from detaching completely.
  5. Jabra Speak 510 Speaker Replacement, Speaker: step 5, image 1 of 2 Jabra Speak 510 Speaker Replacement, Speaker: step 5, image 2 of 2
6 other people completed this guide.
Jordan Murphy
717 Reputation
3 Guides authored
IUPUI, Team 2-3, Harley Spring 2016 Member of IUPUI, Team 2-3, Harley Spring 2016
IUPUI-HARLEY-S16S2G3
4 Members
8 Guides authored
2 Comments
soleniall buen aporteee
bryanpinedaza - Reply
Excelente aporte! Me sirvió mucho!
Alex - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 37
All Time: 5,401
