Jam Voice Motherboard Replacement
  1. Jam Voice Motherboard  Replacement, Hard Mesh Cover: step 1, image 1 of 2 Jam Voice Motherboard  Replacement, Hard Mesh Cover: step 1, image 2 of 2
    • Insert the plastic opening tool underneath the mesh top.
    • Pry the cover open.
    • To reattach the cover, simply align the round posts on the bottom of the cover into the holes.
  2. Jam Voice Motherboard  Replacement, Motherboard: step 2, image 1 of 1
    • Remove the four 7mm Phillips screws from the plastic cover.
  3. Jam Voice Motherboard  Replacement: step 3, image 1 of 2 Jam Voice Motherboard  Replacement: step 3, image 2 of 2
    • Remove the four 5mm Phillips screws that hold down the speaker in place.
    • Remove the two 6mm Phillips screws that hold down the plastic casing.
  4. Jam Voice Motherboard  Replacement: step 4, image 1 of 1
    Tool used on this step:
    Halberd Spudger
    $2.99
    Buy
    • Once all six screws are removed, use a Halberd Spudger or similar tool to lift up the speaker.
    • Pull the speaker up and out.
  5. Jam Voice Motherboard  Replacement: step 5, image 1 of 3 Jam Voice Motherboard  Replacement: step 5, image 2 of 3 Jam Voice Motherboard  Replacement: step 5, image 3 of 3
    • Remove the four 7mm Phillips screws to expose the motherboard.
  6. Jam Voice Motherboard  Replacement: step 6, image 1 of 1
    • After removing all of the screws from the plastic cover, remove it by pulling up and out.
    • Be careful not to pull and damage any of the wires.
  7. Jam Voice Motherboard  Replacement: step 7, image 1 of 2 Jam Voice Motherboard  Replacement: step 7, image 2 of 2
    • Remove the three 5mm Phillips screws that hold the motherboard in place.
    • After the screws are removed, place two fingers on the power button and Bluetooth button to push the motherboard out.
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 9
All Time: 330
