Jazz UltraTab C855 Camera Replacement
  1. Jazz UltraTab C855 Camera Replacement, Back Cover: step 1, image 1 of 1
  2. Jazz UltraTab C855 Camera Replacement: step 2, image 1 of 1
    • Pry the back case off using the blue Plastic Opening Tools. Work one along the seem until you can get your fingers under to pull it apart.
  3. Jazz UltraTab C855 Camera Replacement, Camera: step 3, image 1 of 1
    • Remove the two screws holding the internal camera in place.
  4. Jazz UltraTab C855 Camera Replacement: step 4, image 1 of 1
    • Carefully remove the tape of the ribbon cables attached to the camera.
  5. Jazz UltraTab C855 Camera Replacement: step 5, image 1 of 1
    • Using a plastic opening tool, lift open the tab that holds the connection between the camera and motherboard in place. The ribbon cable will become detached.
  6. Jazz UltraTab C855 Camera Replacement: step 6, image 1 of 1
    • Finally, detach the camera lenses from the cover by gently pulling them away from the case.
Kyle Haas
245 Reputation
1 Guide authored
IUPUI, Team 1-3, Baechle Fall 2015 Member of IUPUI, Team 1-3, Baechle Fall 2015
IUPUI-BAECHLE-F15S1G3
5 Members
10 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 206
