Jensen JTA-230 Cartridge/Needle Replacement
  1. Jensen JTA-230 Cartridge/Needle Replacement, Cartridge/Needle: step 1, image 1 of 1
    • Open the dust cover
  2. Jensen JTA-230 Cartridge/Needle Replacement: step 2, image 1 of 1
    • Next, lift up the clip that holds the tone arm in place and lift the tone arm out.
  3. Jensen JTA-230 Cartridge/Needle Replacement: step 3, image 1 of 1
    • The cartridge and needle is the red piece at the end of the tone arm. To remove it, simply grab the end on each side and pull back slowly. The piece should slide right off the tone arm
  4. Jensen JTA-230 Cartridge/Needle Replacement: step 4, image 1 of 1
    • Once you have the replacement piece it goes on slight different. Instead of it sliding back on, it clips back on. Once the new piece is secured back on it is good to go.
Louis Varrichione
309 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 32
All Time: 5,230
