Jensen JTA-230 Motor Replacement
  1. Jensen JTA-230 Motor Replacement, Turntable Platter: step 1, image 1 of 1
    • Remove Cover from record player.
  2. Jensen JTA-230 Motor Replacement: step 2, image 1 of 1
    • Remove the 4 rubber plugs which hold the turntable platter in place
    • Gently but firmly pull the turntable platter off the axle.
  3. Jensen JTA-230 Motor Replacement: step 3, image 1 of 1
    • Take replacement turntable platter affix it firmly and gently to the axle.
  4. Jensen JTA-230 Motor Replacement: step 4, image 1 of 1
    • Replace rubber plugs
  5. Jensen JTA-230 Motor Replacement: step 5, image 1 of 1
    • Replace Cover
  6. Jensen JTA-230 Motor Replacement, Motor: step 6, image 1 of 2 Jensen JTA-230 Motor Replacement, Motor: step 6, image 2 of 2
    • After removal of the turntable platter, 3 small screws can be seen. Remove the 3 screws which hold the motor in place.
    • On both the right and left side, there are 3 screws, remove each of them.
  7. Jensen JTA-230 Motor Replacement: step 7, image 1 of 2 Jensen JTA-230 Motor Replacement: step 7, image 2 of 2
    Tool used on this step:
    Buy
    • Gently Pull the top off of the sides and flip over to reveal the circuitry.
    • To remove the top entirely, remove each electrical connection with a pair of tweezers. There are 3, each connecting to the speakers.
  8. Jensen JTA-230 Motor Replacement: step 8, image 1 of 1
    • Remove the Motor from the record player
    • Using a soldering iron, remove the motor from the circuitry.
    • Replace motor with new one.
Robert Wilcox
227 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 25
All Time: 1,995
