Jhumki Stone Replacement
  1. Jhumki Stone Replacement, Jhumki Stone: step 1, image 1 of 2 Jhumki Stone Replacement, Jhumki Stone: step 1, image 2 of 2
    • Identify the missing piece.
    • Identify the size of the gem, consider the color, and gauge the depth of the hole.
    • Use the unaffected Jhumki as an example.
  2. Jhumki Stone Replacement: step 2, image 1 of 2 Jhumki Stone Replacement: step 2, image 2 of 2
    • Use an alcohol prep pad to strip the surface of any oils.
    • Repeat this process with the gem.
    • This allows for better adhesion of the glue to the gem.
  3. Jhumki Stone Replacement: step 3, image 1 of 3 Jhumki Stone Replacement: step 3, image 2 of 3 Jhumki Stone Replacement: step 3, image 3 of 3
    • Using your super glue, cover the site of the missing gem completely.
    • Allow for the glue to settle into the cracks before applying the gem.
    • Only apply glue to the hole, being mindful about not overflowing the hole and leaving space for the gem to sit.
  4. Jhumki Stone Replacement: step 4, image 1 of 3 Jhumki Stone Replacement: step 4, image 2 of 3 Jhumki Stone Replacement: step 4, image 3 of 3
    • Use your tweezers to gently grab the gem and place it on the glue.
    • Do not use your fingers as the glue will stick instantly.
    • Use the tweezers to adjust the gem as needed.
  5. Jhumki Stone Replacement: step 5, image 1 of 1
    • After allowing 30 minutes for the gem to dry, use an alcohol pad to remove any excess glue from the jhumki.
  6. Jhumki Stone Replacement: step 6, image 1 of 1
    • Use your polishing cloth to reinstate a beautiful shine to the new gem.
  7. Jhumki Stone Replacement: step 7, image 1 of 1
    • Compare against the unaffected Jhumki and make adjustments as necessary!
    • Enjoy!
    • Use acetone to remove any remaining glue from the jewelry.
Finish Line
Gauri Chahal
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 25
All Time: 167
