Jura 72033 Milk Frother Diode Replacement
  1. Jura 72033 Milk Frother Diode Replacement, Diode: step 1, image 1 of 2 Jura 72033 Milk Frother Diode Replacement, Diode: step 1, image 2 of 2
    • Remove the 2 Phillips screws, then pull off the white rubber feet and open the triangular screws underneath. Special tool.
    • The bottom can be pulled off. Remove the cable holder to be able to work better
    • Unscrew the two circuit boards and disconnect the motor and the sensor cable. The sensor cable with 2 wires remains on the small circuit board.
  2. Jura 72033 Milk Frother Diode Replacement: step 2, image 1 of 2 Jura 72033 Milk Frother Diode Replacement: step 2, image 2 of 2
    • Unsolder SR3100 diode and solder in new diode. 3 A 100 V. The diode had continuity and at the small control board was only 2.5 V at the red and black cable.
    • The temperature sensor resistor is marked green. This has about 95k ohm at room temperature.
    • I also checked the blue marked temperature fuse for continuity and the purple marked contact switch.
Follow the steps in reverse order to reassemble your device
2 other people completed this guide.
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Mini Revollo
960 Reputation
5 Guides authored
erfindergarden foundation Member of erfindergarden foundation
Local Repair Groups
5 Members
42 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 60
All Time: 861
