Jura Capresso IMPRESSA J5 Replacing the heat exchanger
  1. Jura Capresso IMPRESSA J5 Replacing the heat exchanger, Jura Capresso IMPRESSA J5  opening procedure: step 1, image 1 of 1
    • Unplug the power cord!
    • Remove the water tank and the drip tray. Remove all coffee beans from the storage container.
  2. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 2, image 1 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 2, image 2 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 2, image 3 of 3
    • Flip open the lid of the bean compartment.
    • Unscrew the two slotted screws inside the bean compartment. The screws have a rubber washer and will not come out completely.
    • Remove the bean compartment.
  3. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 3, image 1 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 3, image 2 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 3, image 3 of 3
    Tool used on this step:
    iFixit Precision 4 mm Screwdriver Bit
    $2.99
    Buy
    • The top cover is fastened with oval head screws. Unscrew them.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit - also available at iFixit - for their removal. Here a DIY guide. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!
  4. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 4, image 1 of 1
    • Also remove the two oval head screws underneath the ground coffee compartment lid.
  5. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 5, image 1 of 1
    • Now you can pry up the top cover all around.
    • Remove the top cover. This often requires a little force.
    • Use plastic tools to avoid scratching your device.
  6. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 6, image 1 of 2 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 6, image 2 of 2
    • Turn the device with the back facing you.
    • Turn the Jura label a few degrees counterclockwise. If it's hard to do, use a small suction cup.
    • Remove the Jura label.
  7. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 7, image 1 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 7, image 2 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 7, image 3 of 3
    • Underneath the label you will find two Torx T15 screws. Remove them.
    • Carefully pull the top of the chrome cover slightly outwards, then push it down and put it aside.
  8. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 8, image 1 of 1
    • Remove the Torx T15 screw on the side panel with the water tank.
  9. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 9, image 1 of 2 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 9, image 2 of 2
    • Pull the right side panel slightly towards the back.
    • Remove the side panel.
  10. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 10, image 1 of 1
    • Pull the left side panel slightly towards the back and remove it.
  11. Jura Capresso IMPRESSA J5 Replacing the heat exchanger, Jura J5 Magnetic Drainage Valve: step 11, image 1 of 1
    • The motor for the drainage valve is located in the lower side of the unit near the center. It is fastened with three screws and connected with several flat plugs. In the picture, the ceramic valve has already been pushed off.
    • Note: models from J6 onwards have a motor installed and not a magnet.
  12. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 12, image 1 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 12, image 2 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 12, image 3 of 3
    • Unscrew the three Torx T15 screws on the motor for the drain valve. Pay attention to the washers underneath.
    • Carefully pull out the motor.
    • If you want to replace it, you still have to disconnect the flat connectors. Note where the connectors are connected.
  13. Jura Capresso IMPRESSA J5 Replacing the heat exchanger, Heat Exchanger: step 13, image 1 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger, Heat Exchanger: step 13, image 2 of 3 Jura Capresso IMPRESSA J5 Replacing the heat exchanger, Heat Exchanger: step 13, image 3 of 3
    • Here is the removed heat exchanger. You'll find it at the bottom behind the ceramic valve.
    • You should also detach the exhaust valve for better access. To do this, pull off the clip on the right-hand side.
  14. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 14, image 1 of 1
    • The heat exchanger is connected with three hoses, and there is also an outlet in the base plate. When reassembling, make sure the gasket is still in place when you push the heat exchanger in. Make a note of which hose connects where.
    • Disconnect the three hoses and lift the heat exchanger up and out.
  15. Jura Capresso IMPRESSA J5 Replacing the heat exchanger: step 15, image 1 of 1
    • This exchanger was completely calcified and leaking because its cover plate was bent.
Follow the steps in reversed order to disassemble your device
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
VauWeh
212,808 Reputation
265 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 17
All Time: 786
