Jura Impressa S Model right-side panel removal
  1. Jura Impressa S Model right-side panel removal, Right side panel: step 1, image 1 of 3 Jura Impressa S Model right-side panel removal, Right side panel: step 1, image 2 of 3 Jura Impressa S Model right-side panel removal, Right side panel: step 1, image 3 of 3
    • Remove the two Torx T15 screws at the bottom of the side panel.
    • Remove the Torx T15 screw on the front bottom right.
    • Remove the Torx T15 on the right underside of the front access door. Flip the door open a few inches.
  2. Jura Impressa S Model right-side panel removal: step 2, image 1 of 1
    • A metal plate rests loosely on the top of the side panel and holds the rotation sensor in place. Note the position of the plate. Simply lift the plate upwards.
    • When reassembling, make sure that the sheet metal is put back in exactly the same way.
    • First lift the side panel away a little at the bottom, then lift it out at the top.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
212,891 Reputation
265 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 231
