Jura Impressa S model Water Reservoir Seal Replacement
  1. Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: step 1, image 1 of 3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: step 1, image 2 of 3 Jura Impressa S model Water Reservoir Seal Replacement, Water Reservoir Seal: step 1, image 3 of 3
    • Remove the water reservoir.
    • Turn the Jura on its side to have access to the bottom plate
    • The water connector is protected by a plastic cover, which is secured by two plastic rivets.
    • Use some pliers and squeeze the rivets tightly and push them up until they release.
    • Carefully pry up the plastic cover.
    • Insert the new gasket with the flat side facing up.
    • Give some food-proof lubricant to the new seal and replace it.
To reassemble your device, follow these steps in reverse order
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
249,873 Reputation
283 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
29 Members
1,757 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 869
