Jura Z models transformer replacement
  1. Jura Z models transformer replacement, Opening the Jura Z series housing: step 1, image 1 of 1
    • Unplug the machine from the power outlet
    • Remove all attachments: water tank, drip tray, aroma lid
  2. Jura Z models transformer replacement: step 2, image 1 of 3 Jura Z models transformer replacement: step 2, image 2 of 3 Jura Z models transformer replacement: step 2, image 3 of 3
    • Turn the machine so the back is facing toward the front.
    • The Jura sign must be removed. Turn it a few millimeters counterclickwise.
    • If this becomes difficult use a suction cup to assist.
    • Remove the Jura sign.
  3. Jura Z models transformer replacement: step 3, image 1 of 2 Jura Z models transformer replacement: step 3, image 2 of 2
    • Behind the Jura sign are two screws with an oval head. They have to be removed.
    • These screws have an oval head that makes them look like rivets (picture 2). You need to use a special bit for their removal. If the right bit is not available, it could be done with a pair of needle nose pliers. Jura wants to keep us out of our own machines!!!!
  4. Jura Z models transformer replacement: step 4, image 1 of 2 Jura Z models transformer replacement: step 4, image 2 of 2
    • Push the back down a bit and then remove it.
  5. Jura Z models transformer replacement: step 5, image 1 of 1
    • Pull the right side panel- as seen looking to the frontpanel - backwards and take it off.
    • Sometimes it gets a bit stuck and may require a bit more of a pull.
  6. Jura Z models transformer replacement: step 6, image 1 of 3 Jura Z models transformer replacement: step 6, image 2 of 3 Jura Z models transformer replacement: step 6, image 3 of 3
    • In this step, you should remove the screws of the left side panel. The side panel can only be removed after removing the top cover.
    • Remove the Torx T15 screw on the front wall of the side panel.
    • In the side part there is a lid over the brew group. The lid is fastened at the top with two oval head screws. Remove those to remove the lid.
    • With the cover removed the brew group becomes visible
  7. Jura Z models transformer replacement: step 7, image 1 of 3 Jura Z models transformer replacement: step 7, image 2 of 3 Jura Z models transformer replacement: step 7, image 3 of 3
    • This step shows how to remove the top cover
    • Remove the powder tray and all coffee beans.
    • The cover is fastened with three Torx T15 screws. Those are easily visible under the covers as well as the small cover on the left back side.
    • Remove the two Phillips screws on the bean container and remove the bean container.
    • Lift the cover upwards.
    • If it is stuck, use a plastic opening tool to carefully pry it open.
    • The lid of the bean container is held in place by a small, strong magnet that loosely rests. It is either in the green marked recess, or it remains hanging on the bean container. Make sure it is not lost!
  8. Jura Z models transformer replacement: step 8, image 1 of 2 Jura Z models transformer replacement: step 8, image 2 of 2
    • Pull the left side panel backwards to take it off.
    • For some repairs it is not necessary to remove the left side panel.
  9. Jura Z models transformer replacement, Transformer: step 9, image 1 of 2 Jura Z models transformer replacement, Transformer: step 9, image 2 of 2
    • The transformer is located on the side between the ceramic valve and the pump. Depending on the model, a bracket may need to be removed.
    • The pictures depict different models.
  10. Jura Z models transformer replacement: step 10, image 1 of 3 Jura Z models transformer replacement: step 10, image 2 of 3 Jura Z models transformer replacement: step 10, image 3 of 3
    • Unscrew the two low-lying Torx T15 screws from the bracket and remove the bracket.
    • Lift the transformer out.
  11. Jura Z models transformer replacement: step 11, image 1 of 1
    • The transformers are the same in practically all Jura devices.
    • Disconnect the two red (230 V), the two orange flat connectors (15 V), and two yellow ones (9 V) from the transformer.
    • To test the transformer, start by measuring the resistances: the 15 V and 9 V terminals (secondary) should read about 1 Ohm, and the 230 V terminals (primary) should read approximately 100 Ohms.
    • You can also apply an AC voltage of about 20 V to the 230 V (primary) side. You then should measure approximately 1.4 V on the 15 V (secondary) side and around 0.8 V on the 9 V (secondary) side. Never interchange the primary and secondary sides, as it could result in dangerously high voltages.
Work through the steps in reverse order to reassemble your device.
Special thanks to these translators:
de en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
VauWeh
212,943 Reputation
265 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
27 Members
1,209 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 53
All Time: 455
