Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement
Mike Seyman
Mike Seyman and 2 other contributors
Last updated on March 7, 2024
10 minutes
Difficult
Slice and Dice
Introduction
Go to step 1
A printed circuit board (PCB) mechanically supports and electronically connects electronic components using conductive tracks made of copper laminated onto a non-conductive plastic. The PCB reduces the amount of wires in a device and inherently makes any device more reliable. The step by step instructions will describe how to troubleshoot your PCB.
iFixit earns commission when you buy through these links.
  1. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: step 1, image 1 of 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back panel: step 1, image 2 of 2
    Tool used on this step:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing batteries: step 2, image 1 of 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: step 3, image 1 of 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing back half of device: step 3, image 2 of 2
    • Unscrew the other 4, #8 11.6 mm Phillips Head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Positioning device: step 4, image 1 of 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Inspecting PCB: step 5, image 1 of 1
    • Inspect the printed circuit board for any breaks or cracks.
  6. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: step 6, image 1 of 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Removing PCB: step 6, image 2 of 2
    • Remove the 2, #8 11.7 mm Phillips Head screws as well as the 2, #8 7.5 mm screws on the printed circuit board.
  7. Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: step 7, image 1 of 2 Justin Bieber Concert Microphone Printed Circuit Board (PCB) Replacement, Replacing PCB: step 7, image 2 of 2
    • Disconnect all wires from the PCB
    • Remove the damaged PCB from the microphone
    • Place new PCB in the Justin Bieber Concert Microphone.
    • Connect all the wires to the new PCB using this soldering guide.
Mike Seyman
437 Reputation
4 Guides authored
Baylor, Team 4-1, Williams Fall 2014 Member of Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 322
