You're viewing a previously published version of this guide.  View latest version
Older Newer
Justin Bieber Concert Microphone Speaker Replacement
Mike Seyman
Mike Seyman and 2 other contributors
Last updated on March 7, 2024
7 minutes
Moderate
Slice and Dice
Introduction
Go to step 1
The speaker is located at the bottom of the the Justin Bieber Concert Microphone. The user will see there is a problem with the speaker if no sound is being produced. That is if the buttons are working and the batteries have charge. The speaker is the only component in the Justin Bieber Concert Microphone that is capable of producing sound.
iFixit earns commission when you buy through these links.
  1. Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: step 1, image 1 of 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back panel: step 1, image 2 of 2
    Tool used on this step:
    Flathead 1.5 mm Screwdriver
    $5.49
    • Remove the back panel of the device by unscrewing the single #8 11.6 mm Flathead screw on the back of the device.
  2. Justin Bieber Concert Microphone Speaker Replacement, Removing batteries: step 2, image 1 of 1
    • Remove the 3 AAA batteries from the device.
  3. Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: step 3, image 1 of 2 Justin Bieber Concert Microphone Speaker Replacement, Removing back half of device: step 3, image 2 of 2
    • Unscrew the other 4, #8 11.5 mm Phillips head screws to remove the entire back half of the device.
    • Pull apart the device once screws are loose, splitting the device in half.
  4. Justin Bieber Concert Microphone Speaker Replacement, Positioning device: step 4, image 1 of 1
    • Keeping all wires connected to their attachments, place the front half of the device face down.
  5. Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: step 5, image 1 of 2 Justin Bieber Concert Microphone Speaker Replacement, Removing speaker: step 5, image 2 of 2
    • Remove the 2, #8 11.7 mm speaker guard screws with the Phillips Head screw driver.
  6. Justin Bieber Concert Microphone Speaker Replacement, Replacing speaker: step 6, image 1 of 1
    • Disconnect the speaker wires from the speaker and replace it with the new one
    • Refer to this guide for help with soldering the wires back onto the speaker.
Mike Seyman
437 Reputation
4 Guides authored
Baylor, Team 4-1, Williams Fall 2014 Member of Baylor, Team 4-1, Williams Fall 2014
BU-WILLIAMS-F14S4G1
3 Members
4 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 213
