K. Preflight Checklist-Motion
  1. K. Preflight Checklist-Motion, Homing X&Y: step 1, image 1 of 2 K. Preflight Checklist-Motion, Homing X&Y: step 1, image 2 of 2
    • Press Home X. The hot end should move to the left towards the end stop. It will bump the end stop move to the right a few mm, than back left to the end stop and stop.
    • Measure the distance from the edge of the Top X Mount to the edge of the bearing block. Jog the hot end +10mm and re-measure. It should be 10mm larger.
    • Press Home Y. The hot end should move to the back towards the end stop. It will bump the end stop move to forward a few mm, than to the back to the end stop and stop.
    • Measure the distance from the edge of the rear corner to the edge of the bearing block. Jog the hot end -10mm and re-measure. It should be 10mm larger.
  2. K. Preflight Checklist-Motion, Homing Z: step 2, image 1 of 2 K. Preflight Checklist-Motion, Homing Z: step 2, image 2 of 2
    • During bed leveling, you want the probe position to be at the center of the bed, not the nozzle. Once you have your X and Y coordinates calculated press Home Z
    • The probe(not the nozzle) will move to the center of the bed, Deploy the probe, raise the bed, stop once the probe is triggered, and lower the bed.
    • If your probe is slightly off center we need to correct it. Manually jog the hotend so the probe is in the center of the bed. Note the coordinates
    • Take the coordinates off the web page and replace them in homez.g and homeall.g
    • G1 X178.75 Y155.2 F10000 ; go to first probe point
  3. K. Preflight Checklist-Motion, Motion: step 3, image 1 of 1
    • Manually jog the hot end
    • When you jog +X it will move to the right
    • When you jog +Y it will move towards the back.
Finish Line
2 other people completed this guide.
David Husolo
9,232 Reputation
33 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 9
All Time: 1,155
