KDDI Kyocera A5521K Front LCD Screen Replacement
  1. KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: step 1, image 1 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: step 1, image 2 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Disassembling KDDI Kyocera A5521K Faceplate: step 1, image 3 of 3
    • Pry, with a metal probe, the black covers that are located by the pivoting joints of the phone.
    • Beneath the covers are screws.
  2. KDDI Kyocera A5521K Front LCD Screen Replacement: step 2, image 1 of 1
    • Remove the screws using a Y0 screwdriver.
  3. KDDI Kyocera A5521K Front LCD Screen Replacement: step 3, image 1 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement: step 3, image 2 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement: step 3, image 3 of 3
    • Use the iPod pry tool to remove the outer screen.
    • Two screws are now visible.
    • Be careful not to crack the screen upon removal. It is adhered strongly to the phone.
  4. KDDI Kyocera A5521K Front LCD Screen Replacement: step 4, image 1 of 1
    • Use the Y0 screwdriver to remove the screws.
  5. KDDI Kyocera A5521K Front LCD Screen Replacement: step 5, image 1 of 2 KDDI Kyocera A5521K Front LCD Screen Replacement: step 5, image 2 of 2
    • Use the iPod pry tool to loosen the faceplate from the phone.
    • Slide the pry tool along the entire crease of the faceplate to completely detach it.
  6. KDDI Kyocera A5521K Front LCD Screen Replacement: step 6, image 1 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement: step 6, image 2 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement: step 6, image 3 of 3
    • Separate the faceplate from the phone.
  7. KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: step 7, image 1 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: step 7, image 2 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement, Front LCD Screen: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Rotate the phone 180 degrees.
    • Grab the flexible circuit with tweezers (or use your fingers if you can manage a firm grip).
    • Pull the flexible circuit to towards you to separate the front LCD screen from the phone.
  8. KDDI Kyocera A5521K Front LCD Screen Replacement: step 8, image 1 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement: step 8, image 2 of 3 KDDI Kyocera A5521K Front LCD Screen Replacement: step 8, image 3 of 3
    • Firmly pull the flexible circuit from the connector.
    • Be careful not to damage the flexible circuit.
    • The front LCD screen should now be separate from the phone.
Dominic Grisafe
157 Reputation
10 Guides authored
Cal Poly, Team 28-25, Regan Spring 2010 Member of Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Members
20 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 1,525
