Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement
  1. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the hose: step 1, image 1 of 2 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the hose: step 1, image 2 of 2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Remove the bottom cover: step 2, image 1 of 1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: step 3, image 1 of 3 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: step 3, image 2 of 3 Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement: step 3, image 3 of 3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Bottom Cover Replacement, Disconnect the ground wire: step 4, image 1 of 1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
2 other people completed this guide.
Adam O'Camb
199,413 Reputation
416 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 4
All Time: 484
