Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement
  1. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the hose: step 1, image 1 of 2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the hose: step 1, image 2 of 2
    • Make sure the carpet cleaner is turned off and completely disconnected from power.
    • Pull the hose on the rear of the carpet cleaner straight down to disconnect it.
  2. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the bottom cover: step 2, image 1 of 1
    • Use a 3 mm hex key to remove two bolts securing the bottom cover.
  3. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 3, image 1 of 3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 3, image 2 of 3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 3, image 3 of 3
    • Rotate the bottom cover down toward the bottom of the carpet cleaner, then pull it straight back toward the rear of the carpet cleaner to remove it.
    • Don't completely remove the cover yet. There is a ground wire connecting the cover to the carpet cleaner that must be disconnected first.
  4. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the ground wire: step 4, image 1 of 1
    • Pull the yellow and green ground wire connectors straight apart to disconnect the bottom cover's ground wire.
  5. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the pump cover: step 5, image 1 of 1
    • Use a 3 mm hex key to remove the four bolts securing the pump cover.
  6. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 6, image 1 of 2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 6, image 2 of 2
    • Remove the pump cover.
  7. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the vacuum motor assembly: step 7, image 1 of 1
    • Use a flathead screwdriver to loosen the hose clamp securing the flexible hose to the vacuum motor.
  8. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 8, image 1 of 1
    • Use a 3 mm hex key to remove the two bolts securing the vacuum motor cover.
  9. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 9, image 1 of 1
    • Pull the flexible hose straight off of the vacuum motor to remove it.
  10. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 10, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the three screws securing the vacuum motor cover to the vacuum motor.
  11. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 11, image 1 of 1
    • Remove the vacuum motor cover.
  12. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Remove the fan cover: step 12, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the two screws securing the fan cover.
  13. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 13, image 1 of 2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 13, image 2 of 2
    • Remove the fan cover from the vacuum motor.
  14. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement, Disconnect the vacuum motor: step 14, image 1 of 1
    • Use a Phillips #2 screwdriver to remove the screw securing the ground wire to the vacuum motor.
  15. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 15, image 1 of 1
    • Use a pair of flush cutters to cut all the zip-ties securing any wires to the vacuum motor.
  16. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 16, image 1 of 3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 16, image 2 of 3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 16, image 3 of 3
    • Use a pick or small flathead screwdriver to push down on the tab securing one of the motor's power cable connectors while gently sliding the connector out of its slot.
    • Do not completely remove the spade connector yet. The contact underneath it is tensioned by a spring and will fly out if you completely remove the spade connector.
  17. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 17, image 1 of 3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 17, image 2 of 3 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 17, image 3 of 3
    • Use a zip tie, or anything flat and roughly the size of the spade connector, to slide into the slot as you slide the spade connector out of the slot.
    • Make sure the zip tie holds the spring contact down before you remove the spade connector.
    • Your new motor may come with power cables already installed. If so, repeat the last three steps with the new motor to remove its power cables.
    • Leave the zip ties in the new motor until you're ready to plug in the spade connectors.
  18. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 18, image 1 of 2 Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 18, image 2 of 2
    • Repeat the last two steps to remove the other power cable on the vacuum motor.
    • Use the photos in this step as a reference for correctly reinstalling the cables on the new motor.
  19. Karcher Carpet Cleaner BRC3015C 2018 Vacuum Motor Replacement: step 19, image 1 of 1
    • Your new vacuum motor may not come with a vibration damping pad already installed. If so, carefully peel the pad off the old motor and transfer it to the new motor.
Adam O'Camb
199,413 Reputation
416 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 781
