Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement
  1. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Disconnect the spark plug: step 1, image 1 of 2 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Disconnect the spark plug: step 1, image 2 of 2
    • Before you begin, be sure that the engine is powered off and is cool to the touch.
    • Grab the plastic housing at the end of the spark plug wire.
    • Pull firmly to disconnect the wire from the spark plug.
  2. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Remove the pump assembly: step 2, image 1 of 2 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Remove the pump assembly: step 2, image 2 of 2
    • Use a 14 mm socket to remove the four bolts securing the pump assembly to the pressure washer.
  3. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement: step 3, image 1 of 2 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement: step 3, image 2 of 2
    • Pull the pump assembly straight off of the pressure washer to remove it.
  4. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement: step 4, image 1 of 1
    • During reassembly, insert the square key into the slot on the pump motor shaft before you reinstall the pump assembly.
  5. Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Replace the dipstick: step 5, image 1 of 2 Karcher Pressure Washers 11073080 2017 Pump Assembly Replacement, Replace the dipstick: step 5, image 2 of 2
    • The new pump assembly will come with a plug in the oil port. After installing the new pump assembly, remove this plug.
    • Replace the plug with the dipstick from the old pump assembly.
Adam O'Camb
199,443 Reputation
416 Guides authored
One Comment
Estamos interesados en un kit de reconstruccion de una bomba Karcher HD 9/23 DE
Atentamente,
Vicente
Vicente Garcia - Reply
Past 24 Hours: 3
Past 7 Days: 9
Past 30 Days: 48
All Time: 1,731
