Karcher Pressure Washers 15209900 2018 Capacitor Replacement
  1. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Safety precautions: step 1, image 1 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Safety precautions: step 1, image 2 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Safety precautions: step 1, image 3 of 3
    • Before you begin, make sure to power off and unplug the device from the outlet.
    • Unscrew the output hose from the pressure washer.
  2. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the rubber strap: step 2, image 1 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the rubber strap: step 2, image 2 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the rubber strap: step 2, image 3 of 3
    • Unlatch and remove the yellow rubber strap.
  3. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the hand grip: step 3, image 1 of 1
    • Use a T20 driver to remove the two 55mm-long screws securing the hand grip.
  4. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the hand grip: step 4, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the hand grip: step 4, image 2 of 2
    • Remove the hand grip from the extension bars.
  5. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the top panels: step 5, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the top panels: step 5, image 2 of 2
    • Use a T15 driver to remove the six screws securing the top black plastic panels on either side of the device.
  6. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the top panels: step 6, image 1 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the top panels: step 6, image 2 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the top panels: step 6, image 3 of 3
    • Remove the two plastic panels.
  7. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the plastic feet: step 7, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the plastic feet: step 7, image 2 of 2
    • Remove the two T15 screws securing the plastic feet—one screw on either side.
  8. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the plastic feet: step 8, image 1 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the plastic feet: step 8, image 2 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the plastic feet: step 8, image 3 of 3
    • Unclip and remove the plastic feet.
  9. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the housing: step 9, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the housing: step 9, image 2 of 2
    • Use a T15 driver to remove the ten screws securing the housing halves together.
    • Remove the T15 screw underneath the wheel axle.
  10. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the housing: step 10, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the housing: step 10, image 2 of 2
    • Set the device on its side.
    • Lift the housing half away from the body.
    • If the housing half does not separate, check to make sure you removed all the body screws.
    • Remove the housing.
    • Screws may get stuck inside the plastic housing. Be careful not to lose any screws.
  11. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Release the cord strain relief: step 11, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Release the cord strain relief: step 11, image 2 of 2
    • Slide the power cord strain relief out its notch on the plastic housing.
  12. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the motor: step 12, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the motor: step 12, image 2 of 2
    • Lift the motor assembly out of the plastic housing and set it aside.
  13. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Reassembly tip: step 13, image 1 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Reassembly tip: step 13, image 2 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Reassembly tip: step 13, image 3 of 3
    • Reassembly tip: Use these images to help reassemble the housing back around the motor.
    • Make sure that all five bushings are in place.
    • In order for the housing to fit properly, the bushings must fit in their respective mounts.
    • Make sure that the yellow tube is properly notched onto the housing.
    • Make sure that the power cord strain relief sits correctly in the housing notch.
  14. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unscrew the electrical box cover: step 14, image 1 of 1
    • Use a T20 driver to remove the four screws securing the electrical box cover.
  15. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the electrical box cover: step 15, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the electrical box cover: step 15, image 2 of 2
    • Lift the cover off of the electrical box.
  16. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Loosen the capacitor: step 16, image 1 of 2 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Loosen the capacitor: step 16, image 2 of 2
    • Tilt the capacitor upward slightly to gain access to the connectors.
  17. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unplug the capacitor: step 17, image 1 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unplug the capacitor: step 17, image 2 of 3 Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Unplug the capacitor: step 17, image 3 of 3
    • Use your fingers to pull each capacitor connector directly off of their spade plug.
  18. Karcher Pressure Washers 15209900 2018 Capacitor Replacement, Remove the capacitor: step 18, image 1 of 1
    • Remove the capacitor.
    • Reassembly note: The wires are non-polarized and can connect into either plug on the capacitor.
3 other people completed this guide.
Arthur Shi
281,659 Reputation
584 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 8
Past 30 Days: 12
All Time: 2,545
