Karcher Pressure Washers 15209900 Pump Removal
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Karcher Pressure Washers 15209900 Pump Removal, Set the motor upright: step 1, image 1 of 1
    • Set the motor assembly upright with the pump assembly on the top.
    • The pump assembly is filled with oil. This step prevents the oil from spilling out when you remove the pump.
  2. Karcher Pressure Washers 15209900 Pump Removal, Loosen the pump assembly: step 2, image 1 of 1
    • Use a 13mm socket to remove the four long bolts holding the pump assembly to the motor.
    • Re-assembly tip: The bolts hold the pump under pressure against the motor assembly. During reassembly, gradually tighten the bolts in a cross pattern.
  3. Karcher Pressure Washers 15209900 Pump Removal, Remove the pump assembly: step 3, image 1 of 2 Karcher Pressure Washers 15209900 Pump Removal, Remove the pump assembly: step 3, image 2 of 2
    • Lift the pump assembly off of the motor.
  4. Karcher Pressure Washers 15209900 Pump Removal, Remove the pump oil: step 4, image 1 of 1
    • Pour the pump oil out of the motor housing. If the oil looks serviceable, save it for reassembly.
    • Reassembly tip: The piston assembly is sealed with oil, and the motor housing acts as an oil pan. Before you attach the pump to the motor, fill the piston well with oil, up to the bearing plate.
Arthur Shi
281,620 Reputation
584 Guides authored
iFixit Member of iFixit
Staff
118 Members
19,410 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 27
