Katadyne Hiker Water Filter Cleaning
  1. Katadyne Hiker Water Filter Cleaning, Katadyne Hiker Water Filter Cleaning: step 1, image 1 of 1
    • Remove the "snap fit" guard by pulling directly away from the filter body.
  2. Katadyne Hiker Water Filter Cleaning: step 2, image 1 of 1
    • Remove the pump handle by pulling it completely out of the shaft.
  3. Katadyne Hiker Water Filter Cleaning: step 3, image 1 of 3 Katadyne Hiker Water Filter Cleaning: step 3, image 2 of 3 Katadyne Hiker Water Filter Cleaning: step 3, image 3 of 3
    • Use the pump handle to remove the filter cap.
    • Place the horizontal groove of the pump handle depicted in image 1 onto the filter fins.
    • Press the pump handle firmly against the fins and turn the filter counter clockwise.
    • Once unscrewed, remove the filter completely from the body.
  4. Katadyne Hiker Water Filter Cleaning: step 4, image 1 of 3 Katadyne Hiker Water Filter Cleaning: step 4, image 2 of 3 Katadyne Hiker Water Filter Cleaning: step 4, image 3 of 3
    • Only perform this step if solid particles are evident on the outside of the filter.
    • Lightly brush the entire filter with a soft bristled toothbrush under running water.
  5. Katadyne Hiker Water Filter Cleaning: step 5, image 1 of 1
    • Replace the filter inside the filter body and screw clockwise until tight.
  6. Katadyne Hiker Water Filter Cleaning: step 6, image 1 of 1
    • Lubricate the pump handle O-ring extensively with the Katadyne lubricant (sold with pump).
  7. Katadyne Hiker Water Filter Cleaning: step 7, image 1 of 1
    • Replace the pump handle inside the pump handle shaft.
  8. Katadyne Hiker Water Filter Cleaning: step 8, image 1 of 2 Katadyne Hiker Water Filter Cleaning: step 8, image 2 of 2
    • Replace the "snap-fit" guard by pushing directly toward the filter body.
If difficulty pumping persists, a new filter is required.
Dylan Carey
130 Reputation
1 Guide authored
Cal Poly, Team 24-6, Green Winter 2015 Member of Cal Poly, Team 24-6, Green Winter 2015
CPSU-GREEN-W15S24G6
4 Members
15 Guides authored
One Comment
wow. this is very helpful post.
thanks for nice guide line..
plz cheak out this—https://waterfilterhub.com
Kenny J. Jackson - Reply
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 9
All Time: 912
