Kazoo Diaphragm Replacement
  1. Kazoo Diaphragm Replacement, Diaphragm: step 1, image 1 of 1
    • Lay your kazoo down on a flat surface.
  2. Kazoo Diaphragm Replacement: step 2, image 1 of 2 Kazoo Diaphragm Replacement: step 2, image 2 of 2
    • Untwist the cap in the middle of the kazoo and set it to the side.
  3. Kazoo Diaphragm Replacement: step 3, image 1 of 2 Kazoo Diaphragm Replacement: step 3, image 2 of 2
    • Take the damaged diaphragm out with your fingers.
    • If you can't get the damaged diaphragm out with your fingers, turn the kazoo over and let the diaphragm fall out.
  4. Kazoo Diaphragm Replacement: step 4, image 1 of 2 Kazoo Diaphragm Replacement: step 4, image 2 of 2
    • Take a new diaphragm and place it back into the kazoo.
    • Twist the cap back on.
    • If you don't have any kazoo diaphragms, use scissors to cut a plastic wrapper or baking paper to the size of the hole and use that instead.
  5. Kazoo Diaphragm Replacement: step 5, image 1 of 1
    • Take some paper towel and spray isopropyl alcohol on it to wipe off any dirt or dust.
  6. Kazoo Diaphragm Replacement: step 6, image 1 of 1
    • Finally, let the kazoo dry off for 5 minutes, and it will sound new again. Happy playing!
Jose Meza
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 90
All Time: 5,793
