Kenmore 110 Series Washing Machine Electronic Control Replacement
  1. Kenmore 110 Series Washing Machine Electronic Control Replacement, Electronic Control: step 1, image 1 of 1
    • Unplug the washing machine!
    • Using a 5/16" socket wrench or an adjustable wrench, remove the three screws from the top rear of the washer.
    • Lifting from the rear, remove the top panel.
    • The top panel will still be connected by wires and hoses. It will help if you have a flat raised surface to set the top panel on.
  2. Kenmore 110 Series Washing Machine Electronic Control Replacement: step 2, image 1 of 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: step 2, image 2 of 3 Kenmore 110 Series Washing Machine Electronic Control Replacement: step 2, image 3 of 3
    • Using a 5/16" socket wrench or a hand wrench, remove the two screws from the component cover.
    • From the bottom, pull out and remove the component cover.
  3. Kenmore 110 Series Washing Machine Electronic Control Replacement: step 3, image 1 of 2 Kenmore 110 Series Washing Machine Electronic Control Replacement: step 3, image 2 of 2
    • Carefully remove the three wire harnesses.
    • With a phillips head screwdriver, remove the three mounting screws.
10 other people completed this guide.
Robert Trout
1,234 Reputation
5 Guides authored
Cal Poly, Team 15-43, Forte Fall 2012 Member of Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Members
12 Guides authored
3 Guide Comments
the machine is not completing the wash cycle. stop in the rinse and spin cycle.
is there a fix for this?
R Snagg - Reply
I am having the same problem. Did you ever find a fix?
Paul Bennett -
Did anyone find a fix for this problem?
Ron Rafe - Reply
Past 24 Hours: 1
Past 7 Days: 34
Past 30 Days: 153
All Time: 30,843
