Kenmore 110 Series Washing Machine Water Pump Replacement
  1. Kenmore 110 Series Washing Machine Water Pump Replacement, Water Pump: step 1, image 1 of 1
    • Unplug the washing machine!
    • Carefully lay washing machine on its back.
  2. Kenmore 110 Series Washing Machine Water Pump Replacement: step 2, image 1 of 3 Kenmore 110 Series Washing Machine Water Pump Replacement: step 2, image 2 of 3 Kenmore 110 Series Washing Machine Water Pump Replacement: step 2, image 3 of 3
    • Carefully remove both wire harnesses connected to the pump.
    • Squeeze and pull back hose clamp.
    • Twist drain hose off of pump.
    • Using a 1/4" socket wrench, remove the three mounting screws.
    • Pull the pump out of place.
    • Pulling the pump away takes a little force.
14 other people completed this guide.
Robert Trout
1,234 Reputation
5 Guides authored
Cal Poly, Team 15-43, Forte Fall 2012 Member of Cal Poly, Team 15-43, Forte Fall 2012
CPSU-FORTE-F12S15G43
5 Members
11 Guides authored
9 Comments
i have a speed problem with my washer ...
http://tristaterepairs.com/dryer-repair....
Andre Matthew - Reply
please provide info on how to test the water pump once it's removed...
Oscar Ramos - Reply
The instructions say nothing of the pulley belt and wheel.
I'm looking to work on a 110. 81080100
and
I have read that transmission fluid leaks out when the washer is on its side.
Is there a way to temporarily plug it?
thomas - Reply
My clothes are still really wet.
Tracy Schultz - Reply
Washer doesn't move doesn't do any thing it just hummus won't drain water
Hector Rios - Reply
Past 24 Hours: 8
Past 7 Days: 71
Past 30 Days: 323
All Time: 59,546
