Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair
  1. Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Jump Start: step 1, image 1 of 3 Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Jump Start: step 1, image 2 of 3 Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Jump Start: step 1, image 3 of 3
    • This miserable design actually sends line voltage up the hose to the switch, and back down again.
    • If your vacuum is completely dead silent, chances are one of the wires in the hose broke.
    • To start the motor without the hose, get insulated clip leads, apply power, and short the left and right terminals together. If the vacuum starts, you're on the right track.
    • WARNING: Be extremely careful not to touch the exposed contacts when the vacuum is powered in this state.
    • You can also place a small bit of #14 or #12 stranded insulated wire between the two terminals, leaving enough space for plugging in the regular wand. You won't have switch control, but the thing will work.
  2. Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Replacing the Swivel: step 2, image 1 of 2 Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Replacing the Swivel: step 2, image 2 of 2
    • The wire may have broken in various places, but chances are it's broken at the swivel connector.
    • According to "sears parts direct" this model is "too new to have replacement parts". However some parts appear similar to prior models.
    • The following parts are made for a prior model, but appear compatible: KC92PBZTZV06 KC92PBZTZV06.
    • Installation instructions can be found on Youtube at https://www.youtube.com/watch?v=AqjXhGDl...
  3. Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Disassembling the Handle & Switch: step 3, image 1 of 3 Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Disassembling the Handle & Switch: step 3, image 2 of 3 Kenmore 200/400/600 Series Canister Vacuum Cleaner Electrical Repair, Disassembling the Handle & Switch: step 3, image 3 of 3
    • The problem could also be in the handle, which like everything about this vacuum is difficult to service.
    • Remove one screw at the rear of the handle to release the top plate. Now pull. Hard. Straight up. Yes, in this miserable design the motor speed switch is friction fit.
    • Remove the rest of the screws to fully snap the handle apart (mine was stiff).
    • New switches are available, but you'll need a soldering iron and soldering skills for large wires to do work here.
To reassemble your device, throw the parts in the trash and hit Amazon to get a new one.
Bryce Nesbitt
1,023 Reputation
8 Guides authored
2 Comments
the part of the hose that connects to the actual canister is what I believe the issue is. It came apart and when I put it back in nothing happened. Some of the wire clips (they look copper) that are inside of it look broken. Can I just buy a another hose?
Sofia - Reply
just take the handle apart. Put the wires back together. Electrical tape them tight on the inside. After re-assembling, then electrical tape the hose where it comes out of the handle ....wrap the electrical tape around the hose and handle so that the hose no longer moves at the handle. This stops any future wire breakage. Next, never disconnect hose arms when machine is on. And finally, always, always keep filter bags and filter to motor clean. Heppa filter is to keep exhaust air clean, so thats also important. Amazon sells cheap heppa filters.
Bill -
Past 24 Hours: 5
Past 7 Days: 58
Past 30 Days: 256
All Time: 9,944
