Kensington Slimblade Trackball Disassembly
  1. Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: step 1, image 1 of 3 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: step 1, image 2 of 3 Kensington Slimblade Trackball Disassembly, Uncover and Remove the Screws: step 1, image 3 of 3
    • Remove the ball and flip the base over.
    • Take off the rubber feet hiding 4 Phillips (PH1) screws using a spudger.
    • Remove the rubber crown hiding 3 small Phillips (PH0) screws.
    • Remove the seven screws.
  2. Kensington Slimblade Trackball Disassembly, Opening the Case: step 2, image 1 of 3 Kensington Slimblade Trackball Disassembly, Opening the Case: step 2, image 2 of 3 Kensington Slimblade Trackball Disassembly, Opening the Case: step 2, image 3 of 3
    • Using an opening pick, pry up the lower case from the bottom.
    • Tilt the lower case to the left to access the USB cable that is routed through a channel in the lower case.
    • Loosen the cable retainer to free the lower housing.
  3. Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: step 3, image 1 of 3 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: step 3, image 2 of 3 Kensington Slimblade Trackball Disassembly, Remove the Circuit Board: step 3, image 3 of 3
    • Flip up the retaining lever of the ZIF connector on the horizontal optical sensor.
    • Remove the cable from the connector.
    • Flip up the retaining lever of the ZIF connector on the vertical optical sensor.
    • Remove the 3 Phillips PH0 screws securing the circuit board. They are marked with white circles.
    • Remove the circuit board by carefully lifting with a spudger. Place it on a stable support to dust off the micro contacts.
  4. Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: step 4, image 1 of 3 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: step 4, image 2 of 3 Kensington Slimblade Trackball Disassembly, Dust the Circuit Board: step 4, image 3 of 3
    • Dust the button contacts by pressing on them with a spudger and blowing into them with a hand blower. Repeat ten to twenty times for each of the four contacts.
    • Remove the screws from the horizontal displacement sensor.
    • Dust the sensor as needed. (This one is surprisingly clean.)
    • Do the same for the vertical displacement sensor.
To reassemble your device, follow the instructions in reverse order.
Special thanks to these translators:
fr en
100%
Jerry Wheeler is helping us fix the world! Want to contribute?
Start translating ›
Ludovic
710 Reputation
4 Guides authored
Francophones Member of Francophones
Community
45 Members
17 Guides authored
One Comment
Thanks a lot for this tutorial. I have successfully removed the annoying speaker in it. Do you have any suggestions for trackball lubricant. its not smooth when it gets dry.
Akhil - Reply
Past 24 Hours: 2
Past 7 Days: 11
Past 30 Days: 64
All Time: 1,619
