Kenwood CH250 Coupling Replacement
  1. Kenwood CH250 Coupling Replacement, Coupling: step 1, image 1 of 2 Kenwood CH250 Coupling Replacement, Coupling: step 1, image 2 of 2
    • Remove the small cap covering the screw holding the coupling onto the shaft, using a small flat-head screw driver.
  2. Kenwood CH250 Coupling Replacement: step 2, image 1 of 1
    • Unscrew the screw holding the coupling onto the shaft, using the PH1 screw driver.
  3. Kenwood CH250 Coupling Replacement: step 3, image 1 of 1
    • Drag off the old coupling.
  4. Kenwood CH250 Coupling Replacement: step 4, image 1 of 1
    • Clean any dirt around the shaft.
  5. Kenwood CH250 Coupling Replacement: step 5, image 1 of 2 Kenwood CH250 Coupling Replacement: step 5, image 2 of 2
    • Put the plastic washer onto the shaft, then place the metal washer on top of the plastic washer.
    • Note: the old coupling did not have any washers.
  6. Kenwood CH250 Coupling Replacement: step 6, image 1 of 1
    • Push the new coupling onto the shaft.
  7. Kenwood CH250 Coupling Replacement: step 7, image 1 of 1
    • Secure the coupling with the screw, using the PH1 screw driver.
  8. Kenwood CH250 Coupling Replacement: step 8, image 1 of 1
    • Finally, put the cap on top of the screw and press in place with the flat-head screw driver.
Finish Line
Sebastian Gassner
187 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 30
All Time: 105
