Kenwood DNX571HD LCD Touch Screen Replacement
  1. Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: step 1, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement, LCD Touch Screen: step 1, image 2 of 2
    • Turn off the stereo and remove from the vehicle before starting.
    • Unscrew the four 3.5mm side screws with a Phillips #1 screwdriver.
    • There are two screws per side.
  2. Kenwood DNX571HD LCD Touch Screen Replacement: step 2, image 1 of 3 Kenwood DNX571HD LCD Touch Screen Replacement: step 2, image 2 of 3 Kenwood DNX571HD LCD Touch Screen Replacement: step 2, image 3 of 3
    • Use a spudger to unhook the plastic clips on the sides and top of the front panel. There are two clips on each side and one clip on the top.
    • Place the spudger between the plastic tab and the metal case and gently lift the spudger away from the case.
  3. Kenwood DNX571HD LCD Touch Screen Replacement: step 3, image 1 of 1
    • Pull the top of the front panel out and down to remove front panel.
    • Remove the front panel gently so as not to damage the ribbon cables behind it.
  4. Kenwood DNX571HD LCD Touch Screen Replacement: step 4, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 4, image 2 of 2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the main board.
  5. Kenwood DNX571HD LCD Touch Screen Replacement: step 5, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 5, image 2 of 2
    • Flip up the black clasp with the spudger to disconnect the large white ribbon cable from the main board.
  6. Kenwood DNX571HD LCD Touch Screen Replacement: step 6, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 6, image 2 of 2
    • Flip up the black clasp with the spudger to disconnect the small white ribbon cable from the vertical board.
    • Carefully pull the ribbon from the clasp with the spudger.
  7. Kenwood DNX571HD LCD Touch Screen Replacement: step 7, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 7, image 2 of 2
    • Flip up the black clasp with the spudger to disconnect the large orange ribbon cable from the main board.
  8. Kenwood DNX571HD LCD Touch Screen Replacement: step 8, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 8, image 2 of 2
    • Push out the black clasp with the spudger to disconnect the small orange ribbon cable from the main board.
    • Gently push the ribbon out of the clasp with the spudger.
  9. Kenwood DNX571HD LCD Touch Screen Replacement: step 9, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 9, image 2 of 2
    Tool used on this step:
    Buy
    • Using a pair of tweezers, gently pull up on the connector for the power cable to disconnect it from the main board.
  10. Kenwood DNX571HD LCD Touch Screen Replacement: step 10, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 10, image 2 of 2
    • Unscrew the two 4mm screws holding down the board that is standing vertically with a Phillips #1 screwdriver.
    • Pull up on the board to remove it.
  11. Kenwood DNX571HD LCD Touch Screen Replacement: step 11, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 11, image 2 of 2
    • Unscrew the four 5.5mm screws with a JIS #00 screwdriver.
    • Unscrew the 4mm screw with a Phillips #1 screwdriver.
    • Remove the disconnected circuit board.
  12. Kenwood DNX571HD LCD Touch Screen Replacement: step 12, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 12, image 2 of 2
    • Unscrew the four 4mm screws on the main board with a Phillips #1 screwdriver.
    • Gently lift the board out of the casing.
    • Unscrew the 5.5mm screw on the metal plate with a JIS #00 screwdriver.
  13. Kenwood DNX571HD LCD Touch Screen Replacement: step 13, image 1 of 1
    • Carefully remove the tape attaching the power cable to the metal plate.
  14. Kenwood DNX571HD LCD Touch Screen Replacement: step 14, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 14, image 2 of 2
    • Use the spudger to unhook the metal tabs and detach the metal plate from the plastic housing.
    • Place the spudger between the metal tab and the plastic case and gently lift the spudger away from the case.
  15. Kenwood DNX571HD LCD Touch Screen Replacement: step 15, image 1 of 2 Kenwood DNX571HD LCD Touch Screen Replacement: step 15, image 2 of 2
    • Gently press the front of the screen to detach it from the plastic housing.
    • When removing the screen, gently flex out the plastic housing to help get the display past the plastic latch.
4 other people completed this guide.
Wendy Zaballos
952 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 72
All Time: 9,443
