Kenwood DRV-N520 Dashcam Motherboard Replacement
  1. Kenwood DRV-N520 Dashcam Motherboard Replacement, Motherboard: step 1, image 1 of 1
    • Use a Phillips #0 screwdriver to remove the four 3mm screws in the device backing.
    • Remove the back cover.
  2. Kenwood DRV-N520 Dashcam Motherboard Replacement: step 2, image 1 of 1
    • Remove the four 3mm screws in the copper plate using a Phillips #0 screwdriver.
    • Remove the copper plate to gain access to the motherboard.
  3. Kenwood DRV-N520 Dashcam Motherboard Replacement: step 3, image 1 of 2 Kenwood DRV-N520 Dashcam Motherboard Replacement: step 3, image 2 of 2
    • Remove the ribbon cable by gently pulling on it while using a spudger to apply pressure to the lever (orange arrow) holding it in place.
  4. Kenwood DRV-N520 Dashcam Motherboard Replacement: step 4, image 1 of 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: step 4, image 2 of 3 Kenwood DRV-N520 Dashcam Motherboard Replacement: step 4, image 3 of 3
    • Disconnect the speaker connection from the circuit board by using your fingers to apply pressure to the clip holding it in place.
    • Finally, remove the two screws from the two corners of the motherboard using a Phillips #0 screwdriver.
    • Remove the motherboard from the device.
This will conclude the removal of the circuit card. Please refer to the troubleshooting guide for any question.
One Comment
I have a fault with the G FORCE sensor on my device. Any advise on how to deactivate or remove the sensor.
tomle3 - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 8
All Time: 215
