Kenwood KD-37R Turntable Belt Replacement and Modification
  1. Kenwood KD-37R Turntable Belt Replacement and Modification, Turntable Belt: step 1, image 1 of 1
    • Always dust your turntable before performing any maintenance or repairs.
  2. Kenwood KD-37R Turntable Belt Replacement and Modification: step 2, image 1 of 1
    • Remove the rubber mat from the platter and set it aside in a clean, dust free area.
  3. Kenwood KD-37R Turntable Belt Replacement and Modification: step 3, image 1 of 1
    • Remove the metal platter by placing your thumb on the center spindle and two to three fingers in one of the holes.
    • Pull the platter up firmly, but carefully.
  4. Kenwood KD-37R Turntable Belt Replacement and Modification: step 4, image 1 of 1
    • Remove the old belt.
    • Throw the old belt away if it's damaged.
  5. Kenwood KD-37R Turntable Belt Replacement and Modification: step 5, image 1 of 1
    • Turn the metal platter over.
    • Place the new belt around the inner lip of the metal platter, ensuring there are no twists.
  6. Kenwood KD-37R Turntable Belt Replacement and Modification: step 6, image 1 of 2 Kenwood KD-37R Turntable Belt Replacement and Modification: step 6, image 2 of 2
    • Put the metal platter back on the turn table.
    • Use your thumb and forefinger to pull a small section of the belt behind the pulley shaft.
  7. Kenwood KD-37R Turntable Belt Replacement and Modification: step 7, image 1 of 1
    • Replace the rubber mat.
    • Play a record to test the new belt.
    • This is when I discovered the belt that was sent to me was slightly too big. Not to fear! We can fix that.
  8. Kenwood KD-37R Turntable Belt Replacement and Modification: step 8, image 1 of 3 Kenwood KD-37R Turntable Belt Replacement and Modification: step 8, image 2 of 3 Kenwood KD-37R Turntable Belt Replacement and Modification: step 8, image 3 of 3
    • Remove the rubber mat.
    • Before removing the metal platter, carefully remove the belt from behind the pulley shaft.
    • Remove the metal platter and the belt.
  9. Kenwood KD-37R Turntable Belt Replacement and Modification: step 9, image 1 of 2 Kenwood KD-37R Turntable Belt Replacement and Modification: step 9, image 2 of 2
    • Bring two cups of water to a full boil.
  10. Kenwood KD-37R Turntable Belt Replacement and Modification: step 10, image 1 of 3 Kenwood KD-37R Turntable Belt Replacement and Modification: step 10, image 2 of 3 Kenwood KD-37R Turntable Belt Replacement and Modification: step 10, image 3 of 3
    • Turn off heat.
    • Using tongs, fully submerge the belt into the water.
    • Be careful, the water should be very hot for this to work, and can burn your skin.
    • Let the belt sit in the water for between 6-8 minutes.
  11. Kenwood KD-37R Turntable Belt Replacement and Modification: step 11, image 1 of 2 Kenwood KD-37R Turntable Belt Replacement and Modification: step 11, image 2 of 2
    • Using tongs, remove the belt from the water and let it dry completely.
    • The water may still be very hot.
  12. Kenwood KD-37R Turntable Belt Replacement and Modification: step 12, image 1 of 1
    • Repeat steps 5, 6, and 7, and enjoy the music!
Finish Line
Tim
229 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 36
All Time: 217
