Kenwood KDC-BT362U Button Replacement
  1. Kenwood KDC-BT362U Button  Replacement, Front Panel: step 1, image 1 of 1
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U Button  Replacement: step 2, image 1 of 2 Kenwood KDC-BT362U Button  Replacement: step 2, image 2 of 2
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U Button  Replacement: step 3, image 1 of 2 Kenwood KDC-BT362U Button  Replacement: step 3, image 2 of 2
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U Button  Replacement: step 4, image 1 of 2 Kenwood KDC-BT362U Button  Replacement: step 4, image 2 of 2
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U Button  Replacement: step 5, image 1 of 1
    • Remove the front panel.
  6. Kenwood KDC-BT362U Button  Replacement, Button: step 6, image 1 of 1
    • Use the Phillips #0 Screwdriver to remove the four screws.
  7. Kenwood KDC-BT362U Button  Replacement: step 7, image 1 of 2 Kenwood KDC-BT362U Button  Replacement: step 7, image 2 of 2
    • Use the plastic opening tool to pry it open.
  8. Kenwood KDC-BT362U Button  Replacement: step 8, image 1 of 2 Kenwood KDC-BT362U Button  Replacement: step 8, image 2 of 2
    • Lift and remove the motherboard to reveal the inside of the front panel.
  9. Kenwood KDC-BT362U Button  Replacement: step 9, image 1 of 2 Kenwood KDC-BT362U Button  Replacement: step 9, image 2 of 2
    • Use the plastic opening tool to lift up and remove the cover.
  10. Kenwood KDC-BT362U Button  Replacement: step 10, image 1 of 1
    • The buttons are now able to be removed and replaced if damaged or missing.
2 other people completed this guide.
Steven Chov
349 Reputation
3 Guides authored
USF Tampa, Team 2-5, Cagle Fall 2016 Member of USF Tampa, Team 2-5, Cagle Fall 2016
USFT-CAGLE-F16S2G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 21
All Time: 790
