Kenwood KDC-BT362U Metal Case Separation
  1. Kenwood KDC-BT362U Metal Case Separation, Front Panel: step 1, image 1 of 1
    • Locate the face-plate eject button.
  2. Kenwood KDC-BT362U Metal Case Separation: step 2, image 1 of 2 Kenwood KDC-BT362U Metal Case Separation: step 2, image 2 of 2
    • Press the eject button with your forefinger.
    • Remove the face-plate.
  3. Kenwood KDC-BT362U Metal Case Separation: step 3, image 1 of 2 Kenwood KDC-BT362U Metal Case Separation: step 3, image 2 of 2
    • Starting on the top side, pop the front panel frame out.
    • Remove the face-plate frame.
  4. Kenwood KDC-BT362U Metal Case Separation: step 4, image 1 of 2 Kenwood KDC-BT362U Metal Case Separation: step 4, image 2 of 2
    • Use the plastic opening tool to pry open the tabs.
    • Repeat on the opposite side.
  5. Kenwood KDC-BT362U Metal Case Separation: step 5, image 1 of 1
    • Remove the front panel.
  6. Kenwood KDC-BT362U Metal Case Separation, Metal Case: step 6, image 1 of 3 Kenwood KDC-BT362U Metal Case Separation, Metal Case: step 6, image 2 of 3 Kenwood KDC-BT362U Metal Case Separation, Metal Case: step 6, image 3 of 3
    • Use the Phillips #0 Screwdriver to remove the screws off of the metal case.
  7. Kenwood KDC-BT362U Metal Case Separation: step 7, image 1 of 3 Kenwood KDC-BT362U Metal Case Separation: step 7, image 2 of 3 Kenwood KDC-BT362U Metal Case Separation: step 7, image 3 of 3
    • Carefully separate the top and bottom halves of the metal case apart.
    • Do not separate the metal case halves completely.
    • Carefully pull the DVD-Drive ribbon cable from the motherboard.
Pablo Cabrera
201 Reputation
2 Guides authored
USF Tampa, Team 2-5, Cagle Fall 2016 Member of USF Tampa, Team 2-5, Cagle Fall 2016
USFT-CAGLE-F16S2G5
4 Members
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 353
