Kenwood KDC-BT565U Fuse Replacement
  1. Kenwood KDC-BT565U Fuse Replacement, Fuse: step 1, image 1 of 1
    • The fuse can be found on the back of your radio indicated by the red square in the photo.
  2. Kenwood KDC-BT565U Fuse Replacement: step 2, image 1 of 2 Kenwood KDC-BT565U Fuse Replacement: step 2, image 2 of 2
    • Pinch the fuse head with your fingers or a gripping tool to remove. This may require some force.
    • Reinsert a fuse that has the same amperage of the fuse that was previously removed (10 amps).
To reassemble, follow these instructions in reverse order.
4 other people completed this guide.
Darren Evans
273 Reputation
2 Guides authored
USF Tampa, Team S2-G5, Lacy Spring 2017 Member of USF Tampa, Team S2-G5, Lacy Spring 2017
USFT-LACY-S17S2G5
4 Members
11 Guides authored
7 Comments
I disconnect the negative side on my 502 DPX Kenwood in-dash stereo system I replace the alternator and hook everything back up and now I have no power to the receiver
jasonfisher036@gmail.com - Reply
it does not explain how to pull the reciever out.
d_lalande - Reply
same problem, how to remove the receiver
Jason Armondo - Reply
I accidentally touch power on the radio casing now the radio will not turn on and the fuse is good I need help it’s a kenwood KDC-7011
Javier Castellanos - Reply
Did you ever find problem why your radio wouldn't turn on? Can you share with me. I have same problem
Jannie watkins -
Past 24 Hours: 10
Past 7 Days: 64
Past 30 Days: 236
All Time: 21,864
