Kenwood KMM-BT522HD Button Replacement
  1. Kenwood KMM-BT522HD Button Replacement, Face Plate: step 1, image 1 of 1
    • Press the ejection button on the lower left corner of the face plate.
  2. Kenwood KMM-BT522HD Button Replacement: step 2, image 1 of 2 Kenwood KMM-BT522HD Button Replacement: step 2, image 2 of 2
    • Remove the face plate by pulling upwards and in the direction of the ejection button.
  3. Kenwood KMM-BT522HD Button Replacement, LCD Screen: step 3, image 1 of 1
    • Remove the three 7.5mm Phillips #1 screws.
  4. Kenwood KMM-BT522HD Button Replacement: step 4, image 1 of 2 Kenwood KMM-BT522HD Button Replacement: step 4, image 2 of 2
    • Separate the two halves of the housing by prying along the length of the device with a plastic opening tool.
  5. Kenwood KMM-BT522HD Button Replacement: step 5, image 1 of 1
    • Remove the motherboard from the housing.
  6. Kenwood KMM-BT522HD Button Replacement, Buttons: step 6, image 1 of 2 Kenwood KMM-BT522HD Button Replacement, Buttons: step 6, image 2 of 2
    • Remove the 5.5 mm Phillips #00 screw.
    • Remove the clear plastic piece by carefully prying it away from the plastic housing.
  7. Kenwood KMM-BT522HD Button Replacement: step 7, image 1 of 2 Kenwood KMM-BT522HD Button Replacement: step 7, image 2 of 2
    • Remove the gray rubber piece by pulling it upwards and away from the plastic housing.
    • Use the pointed end of a spudger to pry out the buttons.
Andrew Waldon
265 Reputation
3 Guides authored
IUPUI, Team S2-G4, Harley Summer 2018 Member of IUPUI, Team S2-G4, Harley Summer 2018
IUPUI-HARLEY-SU18S2G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 243
