Keurig B60 Handle Replacement
  1. Keurig B60 Handle Replacement, Handle: step 1, image 1 of 1
    • Lift the handle
  2. Keurig B60 Handle Replacement: step 2, image 1 of 3 Keurig B60 Handle Replacement: step 2, image 2 of 3 Keurig B60 Handle Replacement: step 2, image 3 of 3
    • Locate and remove the two 9.5 mm Torx T15 screws on both sides of the handle.
  3. Keurig B60 Handle Replacement: step 3, image 1 of 2 Keurig B60 Handle Replacement: step 3, image 2 of 2
    • Remove the broken handle and replace with the new one
2 other people completed this guide.
Jake Wynn
836 Reputation
5 Guides authored
Cal Poly, Team 1-7, Maness Spring 2016 Member of Cal Poly, Team 1-7, Maness Spring 2016
CPSU-MANESS-S16S1G7
5 Members
10 Guides authored
3 Guide Comments
The handle is locked up, partially ajar. Inserted a k-cup and handle locked when I was pulling it down
Meme Hill - Reply
Handle is locked in a partial open position. I raised handle, inserted-cup and when the handle
was pulled down it locked halfway down and does not move
Meme Hill - Reply
I also have a similar problem as Meme Hill, where the k cup area jostles and jams to an awkward position when moving the handle up (it cannot go up all the way), and it prevents full access to k cup, but I don't know why or what is preventing proper operation of handle swing. My current work around is keep on trying opening and closing, and eventually the handle can open all the way, and the k-cup area part swings out, but it really annoying. It should be accessible the first time when putting the handle up.
Lisa Munn - Reply
Past 24 Hours: 3
Past 7 Days: 10
Past 30 Days: 39
All Time: 3,325
