Introduction
In this guide we will show you how to successfully remove the handle from the K-cup.
Remove two 9 mm Phillips #1 screws.
The screws are located on the top of where the K-Cup would be.
Next, remove these two Phillips #1 screws to allow the release of the actual handle from the frame.
For the O rings, we used the plastic prying tools. Just keep in mind that you might want to hold one side of the O ring down while trying to pry off the other side with the other.
Once you get the O rings on both sides out, you can pull the handle by pulling on each side.
