Keurig K40 Handle Replacement
  1. Keurig K40 Handle Replacement, Handle: step 1, image 1 of 1
    • Unscrew one of the 2mm screws on the handle using a T15 screw head. Keep a firm grip on the device so it does not shift out of place.
  2. Keurig K40 Handle Replacement: step 2, image 1 of 1
    • Flip the Keurig over and unscrew the other 2mm screw using the same screw head. Keep a firm grip on the device to prevent it from shifting or falling.
  3. Keurig K40 Handle Replacement: step 3, image 1 of 1
    • Remove the lever by pulling it away from the Keurig.
    • Replace a new handle by putting the Keurig back together the same way it was taken apart.
Andrew Bornemann
476 Reputation
2 Guides authored
USF Tampa, Team 6-1, Eyestone Spring 2016 Member of USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Members
5 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 27
All Time: 2,142
