Keurig K40 Top Water Pump Replacement
  1. Keurig K40 Top Water Pump Replacement, Top Water Pump: step 1, image 1 of 1
    • Begin by removing the top cover from the device.
    • Remove the cover by gently rocking it back and forth with an emphasis on lowering the left side underneath an internal peg.
  2. Keurig K40 Top Water Pump Replacement: step 2, image 1 of 1
    • Unscrew both 1.5mm screws located on the water pump.
  3. Keurig K40 Top Water Pump Replacement: step 3, image 1 of 2 Keurig K40 Top Water Pump Replacement: step 3, image 2 of 2
    • Keeping one hand firmly placed on the device, tug upwards on the water pump until it is separated from the device.
    • The water pump and pipe should now be loose and easy to move as shown.
  4. Keurig K40 Top Water Pump Replacement: step 4, image 1 of 2 Keurig K40 Top Water Pump Replacement: step 4, image 2 of 2
    • Pull on the point where the pipe meets the water pump.
    • The pipe will come loose and the water filter will be free and ready to be replaced.
5 other people completed this guide.
Andrew Bornemann
476 Reputation
2 Guides authored
USF Tampa, Team 6-1, Eyestone Spring 2016 Member of USF Tampa, Team 6-1, Eyestone Spring 2016
USFT-EYESTONE-S16S6G1
3 Members
5 Guides authored
4 Comments
I NEED ONE OF THESE! Where can I find one????
G Steve - Reply
This is a check valve, not the water pump.
Rick Koen - Reply
Please rename this article. The item is not a water pump.
tvyse46 - Reply
I viewed this to replace the pump. But after the checkvalve was replaced through these instructions my K40 works like new. Thank you.
Glenn Stanley - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 39
All Time: 9,510
