Kindle 10 Battery Replacement
  1. Kindle 10 Battery Replacement, Battery: step 1, image 1 of 2 Kindle 10 Battery Replacement, Battery: step 1, image 2 of 2
    • Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
  2. Kindle 10 Battery Replacement: step 2, image 1 of 1
    • Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
  3. Kindle 10 Battery Replacement: step 3, image 1 of 2 Kindle 10 Battery Replacement: step 3, image 2 of 2
    • Use the metal spudger to gently lift the screen out of the back frame.
  4. Kindle 10 Battery Replacement: step 4, image 1 of 1
    • Detach the battery connector from the motherboard.
    • The battery pack may be glued on to the gray plastic frame. Take care when prying it out not to rip the battery, since it is made of a lithium polymer which is flammable and deforms easily.
hzheng2
537 Reputation
4 Guides authored
UMass Dartmouth, Team 1-2, Konn Fall 2024 Member of UMass Dartmouth, Team 1-2, Konn Fall 2024
UMASSD-KONN-F24S1G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 9
Past 7 Days: 77
Past 30 Days: 297
All Time: 2,833
