Kindle 10 LED Status Light Replacement
  1. Kindle 10 LED Status Light Replacement, Battery: step 1, image 1 of 2 Kindle 10 LED Status Light Replacement, Battery: step 1, image 2 of 2
    • Gently use a metal spudger to pry, twist, and lift the bezel away from the display.
  2. Kindle 10 LED Status Light Replacement: step 2, image 1 of 1
    • Remove the eight 2.6 mm screws using a T5 Torx screwdriver.
  3. Kindle 10 LED Status Light Replacement: step 3, image 1 of 2 Kindle 10 LED Status Light Replacement: step 3, image 2 of 2
    • Use the metal spudger to gently lift the screen out of the back frame.
  4. Kindle 10 LED Status Light Replacement: step 4, image 1 of 1
    • Detach the battery connector from the motherboard.
    • The battery pack may be glued on to the gray plastic frame. Take care when prying it out not to rip the battery, since it is made of a lithium polymer which is flammable and deforms easily.
  5. Kindle 10 LED Status Light Replacement, Motherboard: step 5, image 1 of 3 Kindle 10 LED Status Light Replacement, Motherboard: step 5, image 2 of 3 Kindle 10 LED Status Light Replacement, Motherboard: step 5, image 3 of 3
    • Remove the two outer silver screws with a T5 Torx screwdriver.
    • Use your fingers to remove the two gold screws in the middle.
  6. Kindle 10 LED Status Light Replacement: step 6, image 1 of 3 Kindle 10 LED Status Light Replacement: step 6, image 2 of 3 Kindle 10 LED Status Light Replacement: step 6, image 3 of 3
    • Disconnect the two orange clear plastic ribbons on the upper right and center.
  7. Kindle 10 LED Status Light Replacement: step 7, image 1 of 2 Kindle 10 LED Status Light Replacement: step 7, image 2 of 2
    • Pry the motherboard away from the display frame
  8. Kindle 10 LED Status Light Replacement, LED Status Light: step 8, image 1 of 3 Kindle 10 LED Status Light Replacement, LED Status Light: step 8, image 2 of 3 Kindle 10 LED Status Light Replacement, LED Status Light: step 8, image 3 of 3
    • Follow the guide How To Solder to prepare your soldering iron.
    • Turn on the soldering iron.
    • Clean the tip after the old solder has melted by dragging it across a sponge.
    • Prime the soldering iron by touching its tip with a dab of lead-free wire. Your soldering iron is ready when the solder readily melts.
  9. Kindle 10 LED Status Light Replacement: step 9, image 1 of 3 Kindle 10 LED Status Light Replacement: step 9, image 2 of 3 Kindle 10 LED Status Light Replacement: step 9, image 3 of 3
    • Touch the soldering iron's tip to the two joints on the front and back of the LED for 5 seconds, or longer if it is not melted.
    • Use tweezers to pull out the LED once it is loosened.
    • Always use tweezers to handle components near the soldering tip as it will be hot.
  10. Kindle 10 LED Status Light Replacement: step 10, image 1 of 3 Kindle 10 LED Status Light Replacement: step 10, image 2 of 3 Kindle 10 LED Status Light Replacement: step 10, image 3 of 3
    • Search for "Through-Hole Soldering" on this How To Solder guide to ensure you replace and solder the LED correctly.
    • Align your new replacement LED in the correct location.
    • Pull the wires on each side of the new LED through the holes in the circuit where the LED was previously.
    • Solder its joints in the back. Be sure the soldering joints create a concave tent shape indicating a strong connection.
    • Use a tool such as tweezers to hold the new LED in place so that your hands are not near the hot soldering iron.
hzheng2
537 Reputation
4 Guides authored
UMass Dartmouth, Team 1-2, Konn Fall 2024 Member of UMass Dartmouth, Team 1-2, Konn Fall 2024
UMASSD-KONN-F24S1G2
3 Members
6 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 36
All Time: 276
