Kindle Fire Back Case Replacement
Phillip Takahashi
Phillip Takahashi and 5 other contributors
Last updated on April 28, 2022
5 - 10 minutes
Easy
Introduction
Go to step 1
Remove the back case from your Kindle Fire to access its internal components.
iFixit earns commission when you buy through these links.
  1. Kindle Fire Back Case Replacement, Back Case: step 1, image 1 of 3 Kindle Fire Back Case Replacement, Back Case: step 1, image 2 of 3 Kindle Fire Back Case Replacement, Back Case: step 1, image 3 of 3
    • Wedge a plastic opening tool into the lower right corner of the Kindle Fire.
    • Pry the case apart and run the plastic opening tool along the perimeter of the Kindle Fire to release the clips securing the case halves to each other.
    • If you are having extreme difficulty inserting the plastic opening tool, carefully use a metal spudger to undo the first clip, then switch back to the opening tool to avoid scratching your case.
    • It is helpful to pry the bottom of the Kindle Fire away (and out from the side) from the top part. Exerting too much force attempting to split the two without pulling away can cause the tabs on the inside to crack.
    Where can I buy a battery for my kindle fire
    nannyto2 - Reply
    Try EBay or Amazon. make sure you get the right battery for your Kindle , one is for a Kindle HD and the older version........both are 7 ".
    vvenona1954 - Reply
    Remember to remove any sd card first!!! Snapped mine in half.
    lucy_lady_bug - Reply
    I have the first kindle that came out and it doesn't have the same setup how can I open the back of my kindle?
    Kris Sanders - Reply
  2. Kindle Fire Back Case Replacement: step 2, image 1 of 1
    • Once you have freed all the plastic clips, pull the back case off the Kindle Fire.
    Mine has another plastic pc over the m.etal plate
    Keith Long - Reply
14 other people completed this guide.
Phillip Takahashi
87,319 Reputation
87 Guides authored
3 Comments
Simple to follow instructions .
Eric Rester - Reply
where to buy the base panel for my kindle fire 7 tablet
Senthilvel Murugesan - Reply
I was wondering why my kindle case was opening/separating and it was not charging. I opened the case per you instructions and found that the battery has expanded inside ITS case! I hope to be able to get another battery cheaply. Thank you for your help!!
Ellen De - Reply
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 33
All Time: 16,358
