Kindle Fire HD 6 Speaker Replacement
  1. Kindle Fire HD 6 Speaker Replacement, Back Panel: step 1, image 1 of 1
    • Place the device face down on a clean cloth or another smooth surface.
    • In the following steps, you will need to apply some force to your device. If your device is on a rough surface, you may scratch the screen.
    • Insert the plastic opening tool between the device’s front and back panels. You might need to wiggle the tool up and down to wedge it in the gap.
    • Maneuver the tool around the device until the back unclips from the front panel.
  2. Kindle Fire HD 6 Speaker Replacement: step 2, image 1 of 2 Kindle Fire HD 6 Speaker Replacement: step 2, image 2 of 2
    • Carefully separate the back panel from the rest of the device internals.
  3. Kindle Fire HD 6 Speaker Replacement, Speaker: step 3, image 1 of 1
    • Unscrew the two 3.5mm T5 Torx screws at the base of the speaker.
  4. Kindle Fire HD 6 Speaker Replacement: step 4, image 1 of 2 Kindle Fire HD 6 Speaker Replacement: step 4, image 2 of 2
    • Unclip the speaker wire that runs up the side of the battery and clips into the motherboard next to the battery connector. Gently pull it straight up.
  5. Kindle Fire HD 6 Speaker Replacement: step 5, image 1 of 2 Kindle Fire HD 6 Speaker Replacement: step 5, image 2 of 2
    • Lift the speaker out of the device.
2 other people completed this guide.
Cassandra Beck
885 Reputation
5 Guides authored
Cal Poly, Team 70-4, Forte Winter 2015 Member of Cal Poly, Team 70-4, Forte Winter 2015
CPSU-FORTE-W15S70G4
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 11
All Time: 696
