Kindle Fire HDX 7" Power Button Replacement
  1. Kindle Fire HDX 7" Power Button Replacement, Speaker Bezel: step 1, image 1 of 3 Kindle Fire HDX 7" Power Button Replacement, Speaker Bezel: step 1, image 2 of 3 Kindle Fire HDX 7" Power Button Replacement, Speaker Bezel: step 1, image 3 of 3
    • Insert an opening pick underneath the speaker bezel, and slide it along the perimeter to separate it from the tablet.
    • The adhesive is strong and may require an iOpener, or heat gun, to soften.
  2. Kindle Fire HDX 7" Power Button Replacement: step 2, image 1 of 1
    • Remove the speaker bezel.
  3. Kindle Fire HDX 7" Power Button Replacement, Rear Panel: step 3, image 1 of 1
    • Remove the six pink 3mm T3 Torx screws from the back case.
  4. Kindle Fire HDX 7" Power Button Replacement: step 4, image 1 of 2 Kindle Fire HDX 7" Power Button Replacement: step 4, image 2 of 2
    • Wedge opening picks around the perimeter between the display and back case.
    • Work the opening picks around the perimeter until the two halves disengage from each other.
    • Don't completely separate as the display ribbon cable still connects the two.
  5. Kindle Fire HDX 7" Power Button Replacement: step 5, image 1 of 1
    • Use the flat end of a spudger to pry up and disconnect the rear panel press-fit connector from the motherboard.
    • There may be a glue strip between the battery and the outside case. Gently pry the case open and use the flat end of a spudger to separate the glue strip.
  6. Kindle Fire HDX 7" Power Button Replacement, Micro USB Charging Port: step 7, image 1 of 1
    • Remove the four 2.3mm T5 Torx screws from the micro USB port and power button assembly.
  7. Kindle Fire HDX 7" Power Button Replacement: step 8, image 1 of 2 Kindle Fire HDX 7" Power Button Replacement: step 8, image 2 of 2
    • Pry up the ribbon cable from the rear panel with the flat end of a spudger.
    • Remove the micro USB port and power button ribbon cable.
  8. Kindle Fire HDX 7" Power Button Replacement, Power Button: step 9, image 1 of 1
    • Remove the power button from the rear panel.
Blake Klein
73,886 Reputation
50 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 20
All Time: 1,047
