Kindle Touch Rear Casing Replacement
  1. Kindle Touch Rear Casing Replacement, Back Cover: step 1, image 1 of 3 Kindle Touch Rear Casing Replacement, Back Cover: step 1, image 2 of 3 Kindle Touch Rear Casing Replacement, Back Cover: step 1, image 3 of 3
    • Use the plastic opening tool to undo the six plastic clips around the bottom of the back panel of the Kindle.
    • Don't pry the clips on the top half of the back panel.
  2. Kindle Touch Rear Casing Replacement: step 2, image 1 of 2 Kindle Touch Rear Casing Replacement: step 2, image 2 of 2
    • Slide the back panel downward, toward the charging port. This will release the clips on the top half.
    • Once the top clips release, gently lift the back panel away.
  3. Kindle Touch Rear Casing Replacement, Battery: step 3, image 1 of 3 Kindle Touch Rear Casing Replacement, Battery: step 3, image 2 of 3 Kindle Touch Rear Casing Replacement, Battery: step 3, image 3 of 3
    • Use a Phillips #00 screwdriver to remove the five screws.
  4. Kindle Touch Rear Casing Replacement: step 4, image 1 of 3 Kindle Touch Rear Casing Replacement: step 4, image 2 of 3 Kindle Touch Rear Casing Replacement: step 4, image 3 of 3
    • Using the flat end of your spudger, gently pry the battery up and remove it.
  5. Kindle Touch Rear Casing Replacement, Bezel: step 5, image 1 of 2 Kindle Touch Rear Casing Replacement, Bezel: step 5, image 2 of 2
    • Using a Phillips #00 screwdriver, remove the six 4 mm screws to access the front plate.
  6. Kindle Touch Rear Casing Replacement: step 6, image 1 of 3 Kindle Touch Rear Casing Replacement: step 6, image 2 of 3 Kindle Touch Rear Casing Replacement: step 6, image 3 of 3
    • Use the plastic opening tool to pry the bezel from the top and sides
    • The bottom of the bezel will be glued, so be careful when sliding the clips out.
    • The clips can be easily bent, so do not try to force them out. If you do bend some, they can be bent back.
  7. Kindle Touch Rear Casing Replacement, Rear Casing: step 7, image 1 of 1
    • Use your Phillips #00 srewdriver to remove the indicated screws.
    • There are three pairs of screws that are each different. The screws on the top corners are 4 mm #00 Phillips screws, the screws on the bottom corners are 2 mm #00 Phillips screws, and the black bottom center screws are 6 mm #00 Phillips screws.
  8. Kindle Touch Rear Casing Replacement: step 8, image 1 of 2 Kindle Touch Rear Casing Replacement: step 8, image 2 of 2
    • With the screws removed, gently remove the case from the internals.
Adam Yerly
2,031 Reputation
7 Guides authored
USF Tampa, Team 19-5, Blackwell Winter 2015 Member of USF Tampa, Team 19-5, Blackwell Winter 2015
USFT-BLACKWELL-W15S19G5
3 Members
8 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 1,488
