Kindle Voyage Battery Replacement
  1. Kindle Voyage Battery Replacement, Back Panel: step 1, image 1 of 2 Kindle Voyage Battery Replacement, Back Panel: step 1, image 2 of 2
    • Insert a plastic opening tool between the plastic panel shown on the device.
    • Use the tool to pry the plastic away from the device.
    • There will be adhesive holding this piece of plastic to the device. You may have to pull pretty hard to get it separated.
  2. Kindle Voyage Battery Replacement: step 2, image 1 of 1
    • Use an aluminum driver attached with a Phillips head size #00 to remove the four 3mm screws shown in the picture. For reassembly, note that the top two and bottom two screws are different sizes.
  3. Kindle Voyage Battery Replacement: step 3, image 1 of 3 Kindle Voyage Battery Replacement: step 3, image 2 of 3 Kindle Voyage Battery Replacement: step 3, image 3 of 3
    • Once the screws are removed, the back panel can slide off the device.
  4. Kindle Voyage Battery Replacement: step 4, image 1 of 2 Kindle Voyage Battery Replacement: step 4, image 2 of 2
    • Remove the magnetic component with the magnetic head of the aluminum driver.
  5. Kindle Voyage Battery Replacement, Battery: step 5, image 1 of 2 Kindle Voyage Battery Replacement, Battery: step 5, image 2 of 2
    Tool used on this step:
    Plastic Cards
    $2.99
    Buy
    • Use a plastic card to pry the battery away from the device.
    • Gently un-clip the battery plug from the device and remove the battery.
38 other people completed this guide.
Sean Yap
1,488 Reputation
6 Guides authored
Cal Poly, Team 19-12, Maness Winter 2015 Member of Cal Poly, Team 19-12, Maness Winter 2015
CPSU-MANESS-W15S19G12
5 Members
13 Guides authored
19 Guide Comments
Where can I buy a replacement buttery for my kindle voyage?
hegi88 - Reply Share
Where to find a replacement battery for kindle voyage 3G please if any one knows
Himadri Endow - Reply Share
Bump. Cannot seem to procure a new battery for the Kindle Voyage. Nice to know how to replace the old one; just need something to replace it WITH! Thanks for any hints on finding one. Battery model number is: MC-305070, 3.8V 1320mAh/5.01Wh, P/N 58-000056
larryg - Reply Share
Any advance on where one can find a replacement battery for the Kindle Journal?
Charles WRIGHT - Reply Share
Still looking for a source for this battery.
Neil Hall - Reply Share
Past 24 Hours: 12
Past 7 Days: 84
Past 30 Days: 420
All Time: 38,152
