Kingston HyperX Cloud II Microphone Wire Repair
  1. Kingston HyperX Cloud II Microphone Wire Repair, Kingston HyperX Cloud II Microphone Wire Repair: step 1, image 1 of 1
    • Pulling along the edges, take off the padding.
  2. Kingston HyperX Cloud II Microphone Wire Repair: step 2, image 1 of 2 Kingston HyperX Cloud II Microphone Wire Repair: step 2, image 2 of 2
    • Use a Phillips #0 screwdriver to remove the two 11 mm screws from the bracket support.
  3. Kingston HyperX Cloud II Microphone Wire Repair: step 3, image 1 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 3, image 2 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 3, image 3 of 3
    • Remove the inside bracket support and then remove the outside bracket support. Then set it to the side.
    • After removing the bracket support. Expand and remove the microphone speaker from the frame.
  4. Kingston HyperX Cloud II Microphone Wire Repair: step 4, image 1 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 4, image 2 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 4, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the two 7.9 mm screws from the red support attached to the microphone speaker.
  5. Kingston HyperX Cloud II Microphone Wire Repair: step 5, image 1 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 5, image 2 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 5, image 3 of 3
    • Separate the red frame support from the microphone speaker by putting it to the side.
  6. Kingston HyperX Cloud II Microphone Wire Repair: step 6, image 1 of 2 Kingston HyperX Cloud II Microphone Wire Repair: step 6, image 2 of 2
    • Remove the four 11 mm screws on the speaker frame with a Phillips #2 screwdriver.
  7. Kingston HyperX Cloud II Microphone Wire Repair: step 7, image 1 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 7, image 2 of 3 Kingston HyperX Cloud II Microphone Wire Repair: step 7, image 3 of 3
    • Remove the microphone speaker frame.
    • Open the microphone speaker to reveal circuitry.
    • Solder the detached red wire onto the driver.
    • Be cautious not to solder the wrong wire.
Daniel Olaoluwa Ajagbonna
325 Reputation
2 Guides authored
IUPUI, Team 1-4, Harley Spring 2023 Member of IUPUI, Team 1-4, Harley Spring 2023
IUPUI-HARLEY-S23S1G4
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 12
Past 30 Days: 55
All Time: 978
